What would cause a pinion seal to suddenly start leaking badly?
10 years ago I swapped 355 gears in to an 8.8 in one of my cars,
The car has driven about 5000km since then, and made 3 - 1/4 mike passes this summer.
It sat in my garage for two months and did t leak a drop until yesterday.
I drove about an hour to a friend’s place to use his lift to install a line lock. After two hours on the lift there was a 6” diameter puddle of gear lube under the car.
Is it unusual for a major leak to appear so suddenly? What would have caused to to go so bad so fast?
