Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 104
  1. #51
    Look what the big brown truck brought today for the Tbird, a set of LRS 16x7 TRX wheels! These are the Mustang style TRX, but they still look good on Tbirds, and 99% of people wouldn't know the difference lol. Now I just gotta get some tires put on them.
    Matt
  2. #52
    Jan 2004
    Olathe, Kansas
    Nice! It will look great.
    Now stang-less.
    88 Cougar 5.0
  3. #53
    Not a whole lot has been happening with the Tbird besides driving it and enjoying it, but here's an update since June.
    I wanted to finish the fuel system and utilize the return fuel line since it's not a good idea to dead-head an electric fuel pump. So last October I made a homemade brass low pressure regulator kind of like what Walking-Tall did. It uses a brass set screw with a small hole drilled in it as a pseudo jet to regulate fuel going into the return line. I was able to find all of the fittings pretty easily at the hardware store except the brass set screw. Those are difficult to find. I ended up having to special order some from Fastenal.
    Matt
  4. #54
    I also got a new set of Ohtsu 225/55-16 tires for the TRX wheels, and they're on the car now.
    Matt
  5. #55
    I also have everything rounded up to install 11" Mustang front brakes.
    I got these adapters for the brake lines, but I'm not sure they're the right ones yet.
    Matt
  6. #56
    Also Front struts for a 94 Mustang GT
    And finally a set of FMS 3.73 gears. The axle in the Tbird has 2.73s so this should make a big difference going to 3.73s.
    Matt
  7. #57
    Whitestone, NY
    Oh nice. The wheels look really good on there. Are you doing the rear gears yourself?
  8. #58
    Quote Originally Posted by 87gtVIC View Post
    Thanks! They're not correct for a Thunderbird, but I'm happy with how they look on there. I am having a shop I know install the gears. If I had a lift I would do the install, but there's no way my back could stand doing the swap on jackstands laying on concrete lol.
    Matt
  9. #59
    Jan 2004
    Olathe, Kansas
    Is the front lowered? Guessing the sn95 struts fit stock height ok?
    Now stang-less.
    88 Cougar 5.0
  10. #60
    Whitestone, NY
    Quote Originally Posted by 5.0 bird View Post
    I understand. Dad and I did mine back in December 2013...backyard cold concrete...snow around car. lol Gotta do what you gotta do.
  11. #61
    The front isn't lowered, and for Thunderbirds you wanna have SN-95 struts because the strut travel is similar between Thunderbirds and SN-95 Mustangs. 87-93 Mustang struts aren't long enough they top out on bumps. I got the SN-95 struts mainly to fit the narrower strut mount on the 87+ 5.0 Mustang spindles.
    Matt
  12. #62
    Yeah, lowered I use Fox Mustang parts, but if it's stock-ish height, I use SN-95 stuff.
    I've used new take-off SN-95 struts before on lowered cars, because they were free. Not ideal, but you know...free.
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
  13. #63
    Jan 2004
    Olathe, Kansas
    Quote Originally Posted by Chuck W View Post
    Thanks guys. guess I need to find some sn95 bilsteins.
    Now stang-less.
    88 Cougar 5.0
  14. #64
    Picked up my GT40 heads from the machine shop today! I had them rebuild the heads and install a Trick Flow spring kit.
    I also got my gears installed a few weeks ago. Going from 2.73 to 3.73s was exactly what this car needed. The shop said it wouldn't cost any extra labor to rebuild my trac-lok while they did the gear swap so I bought a clutch kit.
    After I got the car back from the shop I swapped out the speedo gear
    So next up is upgrading the front brakes and putting the heads on.
    Matt
  15. #65
    Mar 2013
    Where the Navy sends me...
    Uh oh, the shop shrank one of the heads!
  16. #66
    Lightbulb
    It's got mixed up with a Fix.It.Again.Tony 8V 2 liter head fellas.
    http://www.museomotori.unipa.it/sche...?id=41&lang=en
  17. #67
    Started the 11" brake upgrade last week. I went with 94 Mustang GT front struts that I learned have a shorter top bolt about 1/2" shorter than Thunderbird struts. The nut just barely threads on so I modified the strut mount. I ended up cutting a 1/2" out of the spacer in the strut mount.
    While we were bleeding the brakes I discovered the master cylinder was slowly losing pressure so I replaced it.
    Now it just needs an alignment and that should finish the 11" brake upgrade.
    Matt
  18. #68
    Today, I decided to start tearing down the motor to install my GT40 heads.
    Next is to drop the heads on with fresh gaskets and start reassembly
    Matt
  19. #69
    Feb 2009
    Jackson, NJ 08527
    Love the new rims, very classy look.
  20. #70
    Started on reassembly!
    Matt
  21. #71
    Finished putting it together and fired it up today!
    Also received a visit from the big brown truck.
    I picked up a set of the LMR mesh wheels for my Mustang a while back, and I liked them well enough that I got a set for the Thunderbird too. So I'm gonna be listing the TRX wheels for sale soon.
    Matt
  22. #72
    Jan 2004
    Olathe, Kansas
    Looks nice! Hows it sound?
    Now stang-less.
    88 Cougar 5.0
  23. #73
    Thanks, it sounds pretty much the same with the gt40 heads just louder.
    Matt
  24. #74
    The ol’ bird is looking good. You have definitely given her new wings! Can’t wait to see the mesh wheels . I contacted LMR and asked if they had plans to get any other color mesh wheels and they said “not at this time “. My car is blue and I want the silver wheels. Definitely post more pictures.
  25. #75
    Awesome build. I like how you did things in steps instead of bombing it with a bunch of parts. That lets you see how much each modification adds or contributes.
    Cant wait to see what you have planned next when its done.
