Results 1 to 7 of 7
    Jul 2016
    Duncannon PA
    Default 1979 vacuum diagrams
    Does anyone have the vacuum diagrams for a 79 302 manual trans car? I just rebuilt the carb and want to make sure everything is hooked correctly. There were some lines plugged and fittings capped when I got the car.
    I looked in the fep library but all I found was 2.3 vacuum schematics.
    Current Mustangs
    1966 6 cylinder coupe
    1984 SVO 9W
    1985 Saleen #132
    You will need your calibration number to find the right diagram.
    http://myzephyrs.com/vacuum_diagrams.htm
    Jul 2016
    Duncannon PA
    WTH is a calibration number???
    Current Mustangs
    1984 SVO 9W
    1985 Saleen #132
    It can be found on the sticker on your valve cover.
    This shows all of what you will eventually need.
    http://myzephyrs.com/calibration_number.htm
    Jul 2016
    Duncannon PA
    HAH! You're assuming that sticker is still there. Its not��
    Current Mustangs
    1984 SVO 9W
    1985 Saleen #132
    Calibration sticker details from FoxChassis posts.
    Davids car is automatic, but this is the general idea...
    Quote Originally Posted by 79mustangcobra View Post
    Foxchassis
    I was looking at my valve cover sticker on my Cobra last night. Can you decode mine?
    C1 KJ326AA
    C1= Cleveland Engine Plant 1
    K = ?
    J = Thermactor w/ A/C ?
    326 = 5.0L engine (300-380) ?
    A = design level ?
    A= ?
    Thanks!
    C1 KJ326AA
    K = 49-state
    A = design level
    A = calibration & revision level
    Then you use Mr K's system and get 58 choices. That's normall. You eliminate the wrong choices, and you get your 5.0L 8 CYLINDER 302 CID Vehicle Emission Control Information (VECI) label.
    Easy as AC Zap Pow DC.....
    9-7Z-R10
    9-10A-R0 9-10B-R0 9-10C-R0 9-10C-R11 9-11A-R0 9-11A-R10
    9-11A-R11 9-11A-R20 9-11B-R0 9-11B-R10 9-11B-R11 9-11B-R12
    9-11C-R1 9-11C-R10 9-11D-R11 9-11E-R1 9-11E-R10 9-11E-R13
    9-11F-R1 9-11H-R10 9-11J-R0 9-11J-R10 9-11J-R13 9-11J-R20
    9-11N-R0 9-11N-R10 9-11P-R0 9-11P-R2 9-11Q-R1 9-11Q-R15
    9-11R-R0 9-11R-R10 9-11S-R0 9-11V-R0 9-11V-R10 9-11X-R10
    9-11Y-R0 9-11Z-R0 9-53G-R0 9-53G-R10 9-53G-R12 9-53G-R13
    9-53H-R0 9-53H-R10 9-54A-R0 9-54G-R0 9-54H-R0 9-54H-R10
    9-54J-R1 9-54J-R10 9-54R-R0 9-54S-R0 9-54S-R10 9-54T-R0
    9-54T-R10 9-54U-R0 9-54U-R10
    You can work backwards from the VECI label, but it has to be manual, not this auto one.
    I'd punt for this one
    http://myzephyrs.com/VAC_5.0/9-11B-R12.html
    Jul 2016
    Duncannon PA
    Thanks. That helps..... I think.
    Current Mustangs
    1984 SVO 9W
    1985 Saleen #132
