I'm trying to find the distance from the back bellhousing mounting surface of a 302 block to the outer surface of the flywheel(fox mustang) where the clutch mounts. Doesn't have to be exact, within .050" will probably cut it. If anyone has a Block out of car with a flywheel bolted up to the crank, that would be awesome, much appreciated.
I'm bolting a SHO V6 to a TKO 600 with a TKO-302 lakewhood bellhousing, using a custom made adapter plate. I have a custom mustang flywheel that bolts to the SHO crank and I'll need to space the flywheel out to compensate for the adapter so the starter engagement will be correct. Thanks in advance.
