Results 1 to 5 of 5
    Default 1980 Fairmont 4 door
    1980 Fairmont
    Holley HP EFI system, car is tuned and driven daily. Gets decent MPG
    Water/meth injection system controlled by Holley
    MSD 6al ignition box
    Mustang forged piston 302 short block
    Edelbrock aluminum heads
    Roller rockers
    Hardened pushrods
    GT40 (explorer) Intake
    42lb injectors
    Boost referenced fuel pressure regulator
    On3 70mm turbocharger
    60mm Wastegate
    50mm BOV
    Turbosmart manual boost controller
    Air to air Intercooler
    3 core radiator
    100 amp one wire alternator
    New gas tank with Walbro 255lph fuel pump.
    T5 manual 5spd transmission
    Center Force clutch
    Custom 3" driveshaft
    8.8 rearend with 3.55 gears, they are noisy but will include a set of 3.27 gears with the car.
    31 spline Moser axles with c-clip eliminators
    31 spline Ford trac loc with 8 fricition discs
    Aftermarket rear upper and lower control arms
    Carpet is bad but I have a New ACC black carpet in the box
    New tires front and back
    Super sweet seat covers and floor mats, Sorry no I will not sell them separately they go with the car.
    Car runs and drives nice, runs cool even on very hot days. Ready for its new home. Pictures taken before 5spd swap.
    $6000 car is located just north of Syracuse NY but will drive anywhere.
Size:  172.5 KBName:  1980-turbo.jpg
    1979 Fairmont wagon 414ci (stock block), 88mm T6, TH400, 9" rear 8.92 at 152.
    1980 Boxtop 306 w/70mm, 10.05 at 142.66 (traction limited) Dart blocked 331ci, S480
    1981 Fairmont 4-door project. 441rwhp on 12.5psi. (SOLD)
    Jan 2004
    Olathe, Kansas
    That is a lot of car hiding under that Fairmont sheetmetal in cream paint
    Now stang-less.
    88 Cougar 5.0
    St. Louis, MO.
    Cool sleeper....GLWS!
    Scotty
    Past Pony's.....
    Dec 2008
    Burlington NC
    Love this car! I wish I had the funds right now. Good luck man, I hope she finds a good home.
    $5800, possible trades.
