Results 1 to 18 of 18
    Mar 2015
    Rose Hill,Kansas
    Default Cleaning tail light lens.
    Has anyone ever tried to use denture cleaner like polident the fizzy stuff that you put into water to remove the surface scum off taillight lens? If so did it work.
    I have never tried, but then again I am either lazy or too much of a perfectionist . . . or maybe both if that's possible.
    I generally clean the lenses, then I carefully wet sand them with 400 grit wet sand paper. Then I respray either the black or the grey depending on year model of the lens. After that I mask off the color and reclear the actual lens area with 2K urethane clear. Generally 2-3 coats and the lights look brand new when I am done. Better than replacing and cheaper too in most cases.
    Masked for grey areas
    Name:  2018-11-25 10.20.53.jpg
    Grey areas masked off
    Name:  2018-11-23 12.01.51.jpg
    Sure enough can't find a picture of those finished, but here's another set done with the SVO stripes.
    Name:  2017-02-05 15.57.09.jpg
    Mar 2015
    Rose Hill,Kansas
    86 Capri lens would be charcoal gray? Hard to tell from due to fading
    Quote Originally Posted by dtmilsap View Post
    Yes, 85/86 Capri tail light trim would be the charcoal grey. Same is true for the 85/86 Mustang. Good Luck!
    Mar 2015
    Rose Hill,Kansas
    Having trouble finding charcoal gray. I checked lmr, cj pony and some others. Where can I find.
    Mar 2015
    Rose Hill,Kansas
    Trey, I wet sanded an area. Looks dull after drying, looks great when wet. Will the clear give it the wet look?
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    For the lights I have reused, I was lucky they weren’t terrible.
    I used 3M rubbing compound and power polished with that and the fine polish and they turned out great for me!
    For the charcoal paint, I did not like the LMR grey they said was for SVOs plus it didn’t go far. I changed and went with the SEM brand. Was available in the body shop supply store where I would usually get the SEM trim black I use.
    Darran
    Mar 2015
    Rose Hill,Kansas
    Thanks Trey
    Yes, when you clear the lens they will look slick, shiny, and glossy. Look at the two pictures I posted above. You can see the dull finish after wet sanding. The last picture with the SVO stripes shows the gloss finish thanks to the clear coat.
    As Darren mentioned the SEM 39153 is a good charcoal gray in spray can form for the 85/86 cars. Good Luck!
    Apr 2016
    Sprague River, OR
    I used Trey's method over a year ago for wet sanding with 400 grit paper and then clear coating the lenses. The black is SEM Trim Black paint.
    Join The Conversation
    Jul 2004
    Montebello, CA
    when I did my 86 capri tailights, I wet sanded them with 400, then power buffed them and then hit them with the proper 86 grey paint. came out looking brand new
    Past 4 eyes-
    U.S. NAVY 1980-2009
    Sometime in the not too distant future I will be restoring my tails. My concern with clear coat over time. Will it turn hazy or yellow or simply not stay optically clear? With the these parts getting more rare by the minute just my thoughts. I’m probably over thinking it but as for now hoping that a good buff will do it
    Quote Originally Posted by saleen428 View Post
    I have been clear coating Fox tail light lenses and others for over 20 years now and never had any issues with hazing or yellowing. I custom stripped a set of tail lights on my brand new 1997 F150 Flareside WAY BACK in early 1997. Painted part of them with matching body color base coat and clear. The tail lights still look brand new to this day. That truck has been sitting now for over 10 years outside my old shop in TX in the TX sun, etc. so I don't think its a problem. As with anything the quality of the paint supplies will dictate the longevity. Not saying you have to use the absolute most expensive, but don't expect the bargain clears to last as long. Oh and I have several sets of Fox tail lights that have been done that also look brand new to this day after 10-15 years of being cleared. Good Luck!
    Mar 2015
    Rose Hill,Kansas
    This is the reflective part of my taillight . The pics make look slightly lighter than it is. If I were to paint it in silver to brighten it up would it increase heat from standard bulbs that might cause damage to the lens.
    Jul 2009
    Cherryville n.c.
    I painted mine silver like that a few years ago with no problems
    I seriously doubt you will see any difference in overall heat.
    You can use the Silver paint and there are even the Chrome like paints that are a bit more reflective than normal silver paint that can help increase the brightness of the rear tail lights. Good Luck!
    Wow, I did not know they were molded in the colors. So....as mine have lost so much color, and are obviously bad....what grit to start with? And any decent polishers to buy? I have cloth polishing wheels I can chuck in a drill.
    https://www.amazon.com/SEM-39153-Cha...ps%2C92&sr=8-1
    SEM 39153 is where it's at for charcoal trim. I'll absolutely agree with that recommendation.
    Quote Originally Posted by Ruskiegunlover View Post
    Folks above wet sanded with 400. I'd start there, and then bump up to something higher, and finish it by polishing. You could probably do it by hand but I'd imagine any random action polisher would do the trick as well.
    1986 Mustang GT - 2A, 5 Sp
    2018 Subaru WRX (Daily)
