What is the best way to remove hood decal that's been on for 34 years. Getting ready to paint so i need hood cleaned. Thanks!
This is the way I did it years ago.
1985 GT owned since new
If i can find the Xylene, i'll try that. Did it come up easy or ake alo of scraping. Thanks
i used the eastwood pneumatic rotary removal tool.
(Item #30216 Brand: Eastwood) i had bought it for the wire wheels, but it came with the Adhesive Eraser Wheel, saw i used it to remove the decal. worked great. does generate heat , so you need to move around so the heat does not build up
The Eraser Wheel works really well in almost any drill, including cordless. They wear out quick so you might need 2, and don't bear down on them too hard.
Good luck!
Kenny
does no work. going to rough up the decal then use paint remove.
I think you are missing the boat on the eraser wheels. Cheap, easy and do little to no damage as long as you keep them moving. if you are trying to save the paint is the the easiest, economical and best on the environment (and your health) solution.
Kenny
if you're not trying to save the paint, I bought blasting media at tractor supply and used my media blaster that I bought from harbor freight and it blasted the sticker and paint right off!! no stripping period, the media blasted right through the crusty old sticker!!
