From what I can find out, it appears to be a common problem for the solder to break, which originally held the baffle in place at the fuel pump in the tank, and the recomended fix is to buy a new fuel tank.
Should have researched this nine years ago when I replaced the pump and thought it odd to have loose metal inside the fuel tank.
The car has been on the road, only, for the past 3 years, and it has got me to wondering,
- Is the loose baffle considered dangerous?
- Does it really matter?
-What is likely to happen if I don't replace the tank?
