Results 1 to 14 of 14
    Default Heater Core options (w/AC)
    Now that the Motorcraft heater cores have vanished, the options seem to be limited to the aftermarket replacements which most agree are of questionable quality. There is another option but it is not cheap. The original Ford heater core can be recored by a quality radiator shop. It only takes a few days. I just had one done and will be installing it in my 84 GT or 89 LX Sport.
    Jan 2004
    Olathe, Kansas
    That is cool! How much was "not cheap"?
    Now stang-less.
    88 Cougar 5.0
    I pad $220 for the recore. I paid $110 plus shipping for the last NOS one. It’s a tough price to swallow when the cheap ones are going for $60.
    Jan 2004
    Olathe, Kansas
    True, but that job kinda sucks, I don't want to do it again soon, if I don't have to. I got a Motorcraft one from Rockauto, but they aren't there anymore.
    Now stang-less.
    88 Cougar 5.0
    I searched earlier this week and found no Ford heater cores. Suddenly, today I see an EBay link for NOS heater core posted by PPI. The price is not cheap but not outrageous at $249. Item 154760458492 qty. 2 available.
    I believe I have enough stock to cover my cars.
    Meant to reply earlier, but thanks for heads up on that Ebay listing. I snagged one up at that time.
    Won't need it for a while, but I'd been looking for a NOS heater core and jumped at the opportunity to get one.
    Jun 2003
    Decatur Alabama
    I havent had any problems with the aluminum ones from the parts store. I have yet to have to replace one of them.
    Kendal
    Nov 2004
    Chas. SC
    Once FORD figured out that the outlet should be bigger then the inlet, heater core changes due to joint failure is history. Just keep the antifreeze level correct and change it once in a while and you should be good to go!!
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    Jan 2004
    Olathe, Kansas
    when did they "figure" it out?
    i always put in the inlet restrictor.
    Now stang-less.
    88 Cougar 5.0
    Nov 2004
    Chas. SC
    I changed mine in 2004 (I keep very detailed records) and the replacement had two different size connections. The replacement was purchased at a local auto store that I have done business since the early 70's. Yes i am old..
    One outlet required a 5/8 and the other 1/2 inch hose. changed them while I was at it and fitting the 1/2 to the return was challenging.
    Albert Einstein
    Almost "Stock"
    I think fox bodies use 5/8" and 3/4" hoses. At least my 85 does.
    Nov 2004
    Chas. SC
    I probably had the wrong size down. Thanks!
    Albert Einstein
    Almost "Stock"
    For a while Napa had a aftermarket unit where the tubes were brazed to the body like OE. Sadly it seems those are all gone now and all we have to choose from is a spectra unit in different boxes
    86 Capri-84 LTD a wagon-85 notch-86 notch
    The issue is usually where the tubes go into the core so unless they redid that joint when the replaced the core it's probably fatigued pretty bad. What I've done in the past is put a good chunk of epoxy around the joints tying the 2 tubes together as much as possible with the available room in the heater box. This braces them together and keeps them from moving around and fatiguing.
    steve
