Results 1 to 14 of 14
    Default 1979 zephyr decoding help
    I've got a new to me 79 zephyr and was curious if someone could help me decode the door and buck tag. Pics attached of the tags and the car. Thanks in advance
    Welcome! Looks all sorts of like an ES to me, but your buck tag is missing the stuff my '79 Zephyr ES has that points to that. I think your paint code of 1G is silver though, which was a color they came in.
    More pics?
    I believe the paint code is 1C from what I can tell that's black code for 1979 I'll get some more pictures up
    Quote Originally Posted by Foxfiend View Post
    I think you're right. My mistake.
    Apr 2010
    Portland, Oregon
    Interesting car! ES with stripper (i.e. none) exterior trim; looks like it has the rare-ish rear side window vents.
    Engine/trans? How about some interior pics?
    OBTW: Welcome!
    VIN
    9 = 1979 model year
    E = Mahwah Assembly
    31 = Zephyr 2-door sedan
    F = 5.0L V8 engine
    645655 = 45,655th 1979 Mercury scheduled for production at Mahwah Assembly
    Door Tag
    Date - 08-79 = August 1979 build
    GVWR - 4160 lb/1886 kg = gross vehicle weight rating
    Front GAWR - 2126 lb/964 kg = front gross axle weight rating
    Rear GAWR - 2052 lb/930 kg = rear gross axle weight rating
    F0090 = 0090 lbs front accessory reserve load
    R0081 = 0081 lbs rear accessory reserve load
    Exterior Paint Colors - 1C = Black
    DSO - A7 = Pacific Ford of Canada district sales office
    Body - 66D = Zephyr 2-door sedan
    VR - [blank] = no vinyl roof
    In Trim - VD = smooth-grain all vinyl seating with front vinyl bucket seats (V), Medium Red interior trim color (D)
    AC - [blank] = no factory air conditioner
    R - 2 = AM radio
    S - [blank] = no sunroof
    Ax - 8 = 2.73:1 axle ratio, conventional (non-locking) differential
    Tr - 5 = Tremec SROD 4-speed overdrive manual transmission
    XX = front springs
    VV = rear springs
    Buck Tag
    E = ES option
    F
    - = no factory air conditioner (factory A/C would have been code "A")
    R = road abrasion (lower bodyside protection)
    B
    T
    X
    Q
    -LB
    66Z = Zephyr model line (Z), 2-door sedan (66)
    1C = Black exterior paint color
    F5 = 5.0L V8 engine (F), Tremec SROD 4-speed overdrive manual transmission (5)
    X
    3
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Are the window frames gloss or satin black?
    Love your wheel choice by the way!
    The door window frames are gloss black but the quarter windows are flat black. It currently has a 302 and t5 with 8.8 with 373s from an 84 mustang. I like the 10 holes but I have a 5 lug swap going in and changing to black bullet wheels. So far I've got the mustang center console and dash trim in because I hate woodgrain lol but I still have the original dash trim put away.
    Thanks foxchassis for the information on the tags!!!
    Love this thing!! Keep the 4 lugs and 10 whole wheels. Looks proper this way
    Pic of current engine setup
    I have a foxbody twin turbo kit I've had sitting around for a couple years and I think this is the direction the car is going to go
    Sorry I couldn't decode more on the buck tag. I just don't have enough data.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Very cool. Looks like someone's made some tasteful mods to it. I wonder if the louvers were retrofit.
    I'll bet your buck tag is so different from mine because yours was built at the other plant, and almost a year later.
    After looking at the other tags in the database I have decoded "66Z" as well.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    I decoded three more codes on the buck tag...
    1st dash on second line = no factory A/C
    E = ES option
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
