Results 1 to 11 of 11
    FEP User
    Dec 2012
    Fort Gay, West Virginia
    Default 85 gt underhood light bulb
    what is the correct bulb number for the under hood light bulb? also anyone have pics on how and where it is run and how it hooks up = complete harness....I'm doing a factory correct placement and install.
    Dec 2006
    Middletown, DE
    The bulb is an "89" mini bulb. The end of the under hood light harness attaches to the starter solenoid and then is wire tied to the main harness that runs up the passenger side fender apron, then up to under the hood near the hood hinge. It has plastic clips that clip into the hood. There is a mercury switch in the bulb housing that will turn the light on when the hood is raised.
    The harnesses are not easy to find, but they come up on Ebay from time to time.
    Name:  Underhood light harness.jpg
    85 Mustang GT
    FEP User
    Dec 2012
    I have a harness or at least half of it...was the original a solid wire from the light to the selonoid? meaning no connector in between? cause the light I have looks just like yours but has a connector that is about half way , meaning it'll reach to about the hood hinge where the connector is.
    Here is the under hood of a Capri, Mustang should be the same.Name:  B0A9366A-AF60-4F15-9B58-036F5ACB9148.jpg
    The harness runs over the shock tower to the solenoid with no connector, but it runs through a fusible link. Remember, an unprotected wire is a fire waiting to happen.
    W
    FEP User
    Dec 2012
    Quote Originally Posted by WilliamCapri View Post
    do you know what amp the fusible link is?
    Dec 2006
    Middletown, DE
    The "fusible link" is the blue barrel shaped piece near the end of the wire at the eyelet. The eyelet connects to the starter solenoid. It is a 20ga fusible link (20ga = blue). Typically, the fusible link will protect wiring that is 4 sizes larger than the fusible link. So in this case the wiring should be about 16 gauge. 16 gauge wire should carry about 10 - 12 amps I believe. If your wire harness does not have the fusible link connected to it, there are fusible link repair sections that you can purchase.
    85 Mustang GT
    FEP User
    Dec 2012
    Quote Originally Posted by tbirdman View Post
    thank you!! I think a inline 5 amp fuse will be plenty......I doubt that bulb will draw 10 to 12 amps
    Oct 2017
    south-central WY
    Has anyone tried an LED for the 89 mini bulb?
    Quote Originally Posted by darkd0r View Post
    Yes. I got this one: https://www.superbrightleds.com/moreinfo/engine-compartment-light-bulb/67-led-light-bulb-12-smd-led-tower-ba15s-base/3698/
    Brighter and cooler color than incandescent bulb.
    1985 GT owned since new
    On my 86 the underhood bulb has the same size base as a backup light bulb which is a 1156. I used a LED replacement for that 1156, much brighter and less current draw.
    Oct 2017
    south-central WY
    Thank you both for the info!
