I bought an 85 mustang and it had no heating or cooling system. I finally got all the pieces. I need help with the vacuum lines and where they all connect to. Any help would be appreciated.
I've got an 86 base coupe. It doesn't have any vacuum connections. Heat and cold is driven by cable actuated flapper doors and fan. The 87+ cars had the vac operated blend doors and stuff, as I recall.
Welcome to the Forum!
Imho, you need the Dealer Service Manual to work on a car.
Otherwise, you waste time and a lot of money.
Thankfully, there are a number of manuals for Fox mustangs.
Imho, eventually, you should get them all, if you're planning on keeping the car.
Fwiw, most people are SOL if they take an older car to a mechanic to have a non-common problem fixed.
That's life.
For the vacuum lines, get the following book:
https://www.ebay.com/sch/i.html?_fro...ual&_sacat=085
mustang vacuum manual
For the Dealer Service Manual, get the following books:
https://www.ebay.com/sch/i.html?_from=R40&_nkw=85+mustang+service+manual&_s acat=085
mustang service manual
I suggest:
https://www.ebay.com/itm/1985-MUSTAN...30638890891985
MUSTANG CAPRI SERVICE SHOP REPAIR MANUAL 8 ITEMS 85 + WIRING DIAGRAMS
Price: US $109.99
But, there are also cheaper ones available:
https://www.ebay.com/itm/1985-Contin...35149019091985
Continental Mark VII Thunderbird Cougar Mustang Capri LTD Service Manual
Price: US $19.95
https://www.ebay.com/itm/1985-FORD-C...L/123712342924
https://www.ebay.com/itm/1985-Contin...l/232230612776
Good Luck!
this is for 84 but should be same for 85.
Ok, interesting, the vac setup is AC only because my 86 base car has pretty much the same cable setup as my 1979 did.
Dealer installed A/C uses cables as well. There are two boxes under the dash and two blower motors.
