This is a Holley Avenger (it uses the tiny handheld to make changes, but if you hook a laptop to it, it's a HP system) The touchscreen backlight doesn't work anyway. I bought this used about 5 years ago and haven't used it myself, but I did power the ecu on and update the firmware to V4. I think Holley has V5 now. You can buy any number of harnesses to use just the ECU to run anything from a 2.3 to a 5.0 to LS.
Included 4BBL TBI (old style lower pressure GM type TBI) throttle body. I like it because it uses 23-25 psi so you can use EFI rated rubber hose.
ECU
Handheld
Fuel pump,
Temp sensor
O2 sensor
Map sensor
Main wiring harness
Power harness
$1000 Shipped. Add 3% for Paypal
I've can take any other pictures you would like to see.
