Results 1 to 3 of 3
    Sep 2014
    Freeport NY
    Default A pillar behind fender rubber
    I got this 4 pc rubber plug kit from LMR and I can only find two plugs between the fender and frame. I cant see where the smaller plugs are supposed to go. Does anyone have pics of these locations?
    https://lmr.com/item/PE-990/1979-93-...r-Rubber-Plugs
    Apr 2016
    Sprague River, OR
    They go in the two holes between the hinges. The passenger side will have a 3rd hold for the antenna.
    Join The Conversation
    Sep 2014
    Freeport NY
    Mine doesnt have holes or plugs between the hinges. I found two old plugs behind the fenders. I was able to squeeze my fingers in with the door open. I notice the replacement plugs are a little smaller diameter than the originals.
    Also, I Goggled the part number stamped into the smaller plugs and found this diagram online showing 2 spots that appear to be between the firewall and the fender. I may pull out a wheel well to see whats in between the fender and the firewall. I been meaning to do that anyway because I want to follow the thin plastic vacuum line that starts at the A/C vacuum tee on the firewall and goes to a hole in the inner fender wall. I wanted to replace all that vacuum line with fresh tubing.
    Gonna have to wait awhile though as Im having surgery next week and dont know how long I'll be recovering.
