Results 1 to 16 of 16
    Default Leather 3 spoke steering wheel?
    Did any Mustang/Capri other than the SVO ever get a leather 3 spoke wheel? I don't think so, but I figured I'd ask anyway.
    84 Capri RS Turbo
    USAF 1986-2007 (Ret)
    Apr 2010
    Portland, Oregon
    McLarens.
    Figures.
    84 Capri RS Turbo
    By "3-spoke steering wheel" do you mean only the 1984-86 style steering wheel?
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Yes. I was wondering if it was a bit more common (leather) than it appeared to be. Guess not.
    84 Capri RS Turbo
    Best advice is get a base model LX steering wheel and horn pad and then order a steering wheel and horn pad leather wrap from here: https://www.redlinegoods.com/Mustang7986shiftboot.php Good Luck!
    My RST has a 3 spoke, just not leather. I’m attempting to class it up a bit. I have a leather shift knob and boots are available too. The wheels are hard to find, at least decent ones are.
    84 Capri RS Turbo
    Quote Originally Posted by billkandi View Post
    The link I posted above will work for your steering wheel.
    Just looked. Thanks!
    84 Capri RS Turbo
    For 85-86 for sure .... only the cars without cruise had a three spoke wheel
    Its funny — ends up being whatever you get used to that you end up preferring.
    youll get a chuckle from this
    I like my 85-86 wheel with cruise best, but after putting 1/2 million miles on my 86 I find that the steering wheel texture that’s long gone from my old 86 wheel drives me crazy any time I’m driving other 85-86 cars.
    And worse yet when my steering column broke my wheel was being a complete bitch about coming off the column shaft on the broken column even with good tools. Unfortunately the parts car I got my replacement column from only had about 60K miles and they must have been highway as the texture bumps on the wheel I’m stuck with are way more pronounced than they ever were when I first got my car at 78K in the 1990’s.
    Oh — and my 85 that Trey is working on has even more pronounced steering wheel texture yet. Guess I better get used to it!
    Lols
    Is there a "best" way to clean interior stuff like arm rests and horn pads? I've got some stuff that's kinda sticky and nasty from age/basement storage/whatever.
    84 Capri RS Turbo
    You can try some Dawn dish soap mixed with water in a spray bottle with a soft bristle brush.
    if that doesn’t cut it try Simple Green or something called Tuff-Stuff. It’s in a yellow can I believe. Auto Zone & Advance usually have it. Good luck.
    Ray
    For old plastics, I run them down with Vaseline, especially if they are brittle. Plastics are oil based and you can usually make them a ton better.
    This is what I did with mine
    craft customs in texas can recover your 3 spoke wheel in leather. not cheap but they do a great job.
    I use TuffStuff on dirty plastics. Even do a second round with a scrub brush. It will get most of the dirt off. If you have something else then move up to something solvent based like alcohol or mineral spirits. Goof off works well too. I leave the prepaint solvents until last as they often remove the paint.
