I've been having problems with backfiring. I thought I had it figured out, but I still get an occasional backfire (actually, an "afterfire", as it is coming from the exhaust). I found that I can reproduce the backfire. It will happen at 90%-wot, at higher rpm...around 4k or so. I can reproduce it sitting in the driveway or while driving. Basically, it will happen when I stomp the skinny pedal. However, if I stomp the gas while in "too high" of a gear and rpm's don't increase, I don't get it. I haven't noticed a misfire. I've pulled plugs, checked wiring, checked timing (tried timing at various settings). I don't believe timing or ignition is the culprit.
I did have the idle mix set a little too rich. Plugs were sooty until I got that straightened out, so I didn't originally suspect a lean condition. After fixing the rich idle, I put a few miles on the car and checked plugs again. It looks like a lean condition, which might explain the backfire I'm getting. I'm just looking for advice here. I will be ordering a wideband gauge tonight so I can get a better idea of what's going on, but for now, I'd like to know what you think about my setup. Personally, it doesn't seem like I would be starving for fuel this much with the carb I have. I'm certainly no expert on this, so some input would be helpful.
Here's what I have:
Engine: 331 stroker (stock 302 block). Flotek heads (180cc intake port/58cc chambers), cam 560/560 lift, 280 duration, 110 lsa, around 10.5:1 compression ratio.
Carb: Quickfuel 650 mechanical secondary. Primary jet: 68, Secondary jet: 76, Primary/secondary air bleeds: 73, Primary power valve: 4.5 (no secondary pv).
Here's what the plug looks like. I was thrown off before, because the plugs were previously black/sooty with the rich idle mix. After leaning it out and going for a drive, this is what they look like.
