Results 1 to 4 of 4
    Default How/where do you install these C clips or horseshoe clips for rear drum brakes?
    I bought a drum brake rebuild kit. It came with two of the c clips you see here: https://www.macsautoparts.com/ford_m...d-mercury.html, but I didn't see them on two old sets I took apart and I can't find diagrams anywhere on how they go on. I believe they go on the parking brake cable, maybe? But it didn't look right when I tried using, so i left off. Important? Easy to put on without undoing all my work?
    Feb 2012
    Elizabethton, TN
    Look straight down under the "r" in Drum. (Currie Ford 9 in. Drum Brake Backing Plates)
    https://www.summitracing.com/parts/c...SABEgIBOvD_BwE
    May 2003
    Roseburg Oregon
    The picture referenced from summit shows it on the top right .
    It is for the parking brake pivot .
    Ok, thanks to you both!
