Results 1 to 11 of 11
    Default muffler choices.
    I have lmr special x pipe and american thunder kit.
    But 2000-2200 the drone is mind numbing, so I am trying to figure out the best way to eliminate it,
    different mufflers, add resonators?
    I still want it aggressive with the least amount of drone
    so what combos have people used?
    Jack Hidley
    Jan 2004
    Olathe, Kansas
    Wow! that is interesting, learned something today.
    Now stang-less.
    88 Cougar 5.0
    Ya, that quite a thread good info. I couldn’t see any of the pics though do you need to be logged in to see them
    Sep 2014
    Freeport NY
    I'd like to see pic of that set up too. Does anyone here have examples of what they discuss in the other forum? The posting is old so the pics were probably pulled long ago. I too get annoying drone at 2000 rpm and most cruising speeds. Wifey hates being in my car because of it.
    I have a dual exhaust converted from single. I have stock shorty headers from an 87, a stock H pipe with 4 cats, 2 front cats hollowed out, rear cats function with secondary air system, a pair of MagnaFlow high performance mufflers.
    Just sign up for the Corral. It takes 2 minutes. Then you will be able to see the photos in the thread.
    Jack Hidley
    This has been talked about a few times here.
    vb.foureyedpride.com/showthread.php?188284-Anyone-experimented-with-1-4-wave-resonator-J-pipe-on-their-exhaust
    There's another thread linked in that one too. I've been thinking about this too since I'd like quieter exhaust myself. I wonder if inline resonators would work as well as this seems to. That's what I was thinking I'd do (inline), but maybe not if if this (J-pipe) is that much more effective.
    An inline resonator will be much more complicated to design for a given application. I wouldn't even try without the correct acoustics measuring devices.
    Jack Hidley
    Oh, I would just buy some and slap 'em in, no designing here
    I have been using the expanded metal mesh (for concrete) rolled into a tube and shove in the tail pipes of mine for years now. Not absolutely perfect but significantly reduced the drone and cost almost nothing.
    Yeah, it's pretty interesting that that works as well as it does.
    These are the inline resonators I am referring to.
    https://www.summitracing.com/parts/vpe-1792
    If the cats don't cut the volume enough, I'd be looking to quiet things down in general. When I found the linked resonators, I didn't know about the J-pipe thing. It's certainly interesting to think you can eliminate the drone, but maybe keep more of your volume. The drone is definitely the most unpleasant part of having a loud car... But then you have the issue of engineering the j-pipe yourself. Not something I'm all that interested in attempting.
