Fender tweak
The lower fender here was slightly pushed in by a PO, making the tire rub slightly in right turns. So, this is how I crafted a solution. Worked and didn't damage the irreplaceable lower fender extensions.
Nice!
Are those side pipes on a van too? +1 if they are!
Yep side pipes on the mighty 4.3 V6...the oem Y pipes aren't made anymore so, why not?
- You may not post replies
- You may not edit your posts
Forum Rules
