Results 1 to 2 of 2
    Default First time Capri owner need help with ignition wiring!
    Hello members! I just picked up a 84 capris gs 5.0 ho carbed. It has been 90 percent completed for restoration and engine build however I知 needing help with putting in my msd ready to run distributor and blaster 2.0 coil. I need simple pictures or diagram on how the battery cables should be routed for alt/coil/ground the basic power supply. It has no factory ignition box so I知 confused on how or which ignition wires from the key are needed to make this system turn over/run for me. Any input or help would be great guys!! Thanks in advance
    Welcome to FEP!
    I have moved your post to the Electrical section of the Forum as that is a better choice for your question. Feel free to post a New User Introduction post if you like, pictures are always a great way to say Hi! and get plenty of response from the FEP Members
    At the top of this Forum you will find wiring diagram PDF's of the different year models, etc. that can be a huge help to sort out much of the wiring. I am sure other members can help with pictures of a stock layout of the wiring for an 84 5.0 Fox. Good Luck!
    This might help a bit too.
