Results 1 to 6 of 6
Thread: "Loose" Visors
    Default "Loose" Visors
    Is there anyway to tighten up the Visors? Mine are installed, snug to the headliner, yet when I take off, they want to roll back and not stay in place. I flipped em and put them running along the door, but that doesnt look the best and hopefully someone has a cure to fix them.
    Since that drives me crazy, I have usually modified my headliners and cars to use the later model style that have the additional mount near the center of the car.
    I believe several people have wrapped the sunvisor rod with tape to help create some drag or resistance to the visor rotating while driving. That would be my first option and see if that helps. Good Luck!
    Apr 2009
    Acworth, GA
    I've used a pair of pliers to gently squeeze the metal liner inside the visor so it is tighter to the rod. Only helps for awhile if you're actually using the visors, since the rotation loosens up the metal liner
    In a prior thread about this:
    Solved that with neo magnets in 2017. Works like a charm to this day.
    Can pivot visor down and the magnets still hold visor up. Visor can be pivoted to the side as usual.
    https://www.homedepot.com/p/MASTER-M...47HD/202526369
    The magnets hold just right great. No mods to visors. Small, not really noticeable. Cant see them with visor up.
    My post #22 has details. Post #24 shows them in place.
    http://vb.foureyedpride.com/showthre...-won-t-stay-up
    Sep 2014
    Freeport NY
    Quote Originally Posted by Qwk View Post
    Is there anyway to tighten up the Visors? Mine are installed, snug to the headliner, yet when I take off, they want to roll back and not stay in place. I flipped em and put them running along the door, but that doesn't look the best and hopefully someone has a cure to fix them.
    If you're talking about the way the visor pivots up and own on the long thin rod that holds it, I'll tell you how I fixed mine. I found that even with new visors there was still play because the rod was worn from years of wear and tear. I could see the scoring in the metal. Even getting a used one might still be shot or close to it. So i bought an electric engraver from harbor Fright. A cheap one. https://www.harborfreight.com/electr...ver-46099.html
    I polished the steel rod with sandpaper then I took the engraver and I scored it with lines length and width wise. It raises the metal above the surface and kind of created a spline with the engraver. At first the visor didn't want to go back on easy so I polished the "spline" gently with sandpaper, testing the fit after a few tries I was sure it was right. I smeared a thing coat of never seize on the rod and wiggled the visor back into place.
    In the 5 years since I did that I have had zero flop. They stay where I place them and they are probably a little tighter than they were from the factory. but it's a problem solved permanently and I don't need an ugly magnet. There's nothing to lose by trying it.
    Awesome!!
    THANK YOU guys for the tips!!
