I will soon try starting up my 82 GT after 20 years of storage and want to make sure I do it right/minimize damage from a dry engine.
I've replaced the complete fuel system, rebuilt the carb and now need to focus on the engine itself.
Some say just fog the cylinders, take off the valve covers and squirt oil on all the rocker arms, etc.
Others say, that is not enough and damage will be done.
They say take out the distributor, use one of those extensions on a drill that reach down to the oil pump and drill counter clockwise until oil is seen pumping up through over all the rocker arms. They also say I'd probably have to move the motor manually with a breaker bar in the middle of this to get oil pumping to each area.
My problem is I don't know how to do engine timing and moving the motor with the distributor off would throw that all off. I've watched some timing vids and they make it seem damn complicated/something best left to the experts.
Is there a way to mark things so i could put the distributor back in just for the engine turn portion? Is the oil pump/extension method overkill?
Appreciate any suggestions/advice!
