Results 1 to 4 of 4
    Default 1979 Mecury Capri Temperature Gauge Sending Location
    I'm new to these engines so please forgive me..
    We have a 2.8L 1979 Mecury Capri and the temp gauge is aftermarket and the wires are not connected. I do not see where to connect the sender wire from our gauge cluster. Can anyone show in a picture where it is located?
    If you have an aftermarket gauge then I would expect it to be wired directly to the aftermarket sending unit. The factory wiring would not be used.
    I think I found a sending unit near the water pump, would this not function the same with an aftermarket VDO gauge as the original in the cluster? It seems the unit just connects to a single wire from a pole mounted connection.
    May 2016
    Lake City Pa 16423
    The sending unit must be for the after market gauge. The stock sender will not be correct for the new gauge. They have to be a matched set. You can use the stock wires to hook up the new gauge, but the stock sender has to be change to match the new gauge.
