Results 1 to 3 of 3
    FEP Member Mgino757's Avatar
    Jan 2011
    Virginia Beach, VA
    Default 85 GT: Reverse lights blow fuse
    My 85 GT has started blowing #5 fuse with the reverse light connector on the switch, but not when disconnected. With the switch connected, the fuse will blow only when I take it out of reverse. Putting the transmission in reverse will light up the reverse lights, but as soon as I shift out of reverse, the fuse pops. I checked the wiring, it looks fine. I ohmed the two wires on the switch. The ground side has maybe 3 ohms, the white wire side was showing 73 ohms. I tested the switch, it only has continuity when reverse is engaged. Could it be the switch shorting out when shifting out of reverse?
    May 2016
    Lake City Pa 16423
    The reverse switch is only an open/close switch. When it is not in reverse, the switch is open. When put in reverse, it closes. The switch provides power to turn on the lights when you select reverse. You said the switch ohms out 3 on the ground side? There is no ground side. It is sending battery power straight to ground and blowing the fuse. There should be no reading from the switch to ground on either side of the switch. You should only see a couple of ohms through the switch when it is in reverse, and nothing when it is out of gear.
    You have a switch shorting to ground when it is not in gear. It will need to be replaced.
    Jan 2011
    Virginia Beach, VA
    I replaced the backup light switch. Problem is fixed.
