Does anyone have a photo of how the A-pillar weather strip should look installed. I think the C-channel is bent because the gasket has a gap between the A-pillar and gasket.
Thank you
Thank you
Here is a picture of my 83. Keep in mind there are slight differences between the years. I have 3 t-top cars at the moment and they are all slightly different.
There are plastic plugs to retain the lower part of the seal on the A pillar. As you move up the A pillar it appears to use an adhesive to stay in the channel. I can't quite tell where yours is going wrong from that pic but hopefully these pics help you out.
so it should tuck under my silver trim not lay over it?
It should fit snug over the C-Channel and tuck under the drip rail on your A pillar but over your door glass when the door is closed.
Here are some pics of an earlier car with a shorter piece of weather strip (Nov 81 if I recall correctly). I know it is hard to see with the wet / black.
Sealing / adjusting these old T-Top cars is such a hassle but they are soooooo cool.
Thanks for the help. It definately worth the hassle for the cool factor alone
Gaskets all fitted, and now I have the following issue.
The glass channel run sits out site the new gasket...leaving an air gap. Any help would be appreciated.
Here is from the inside.
The channel strip is being pushed out by the A pillar strip. I am so frustrated.
Here's a pic of my right side
86 Mustang GT T Top 2A 20k miles
95 Toyota FZJ80 Landcruiser triple locked expedition rig
87 Saleen sold
84 GT350 #1808 Sold
86 GT Sold brother has it.
87 Saleen sold
84 GT350 #1808 Sold
87 Saleen sold
84 GT350 #1808 Sold
Sorry for the crappy picture quality. These are better
87 Saleen sold
84 GT350 #1808 Sold
87 Saleen sold
84 GT350 #1808 Sold
So is it just going to take time to break in the new gasket? Also I can get the window set into the gasket when the door is closed but window wont go up if I roll it down with the door closed.
