Results 1 to 6 of 6
    Default 351w block questions
    Might pick up a 351w block that is fresh from shop from being cleaned. Owner told me its a 74. Anything to look for before I buy. I know you will never know if its ok till machine shop checks but just wondering if there is any spots that have common issues to look for. Like the 93+ blocks that crack by the oil passages.
    I am not aware of any specific issues with the early 351W. I am sure like all engines there are some areas of more concern than others, but overall I don't recall there being any Major concerns in regards to durability. Good Luck!
    1969 and 1970 have a .020" shorter deck height, piston selection can be trickier, or use a thicker head gasket. Won't be an issue with a 1974 block though.
    Jess
    Previously owned;
    74 is a damn good W block
    Mar 2003
    Lowell, Oregon
    Just a thought-
    Not sure when the SBF went to a block mounted oil dipstick. The early ones were in the timing cover so if you swap it in to a Fox body that needs a rear sump pan you will need to address that. I am putting a '70 302 block in my Granada. Going to cut a hole in the side of the pan and use a 7.3 diesel dip stick adapter/tube.
    An aftermarket pan will have a dipstick provision.
    Jess
    Previously owned;
