Results 1 to 14 of 14
    FEP Member Boxtop78's Avatar
    Jun 2017
    Stockton,California
    Default Stroke 545 Fairmont
    Hi guys,happy father's day.
    I'm working on my Boxtop project in the process of building a bottom end.
    my question is what trans. cross member to use for a c6 trans? Does a foxbody t5 x-member fit?
    I will post more pics and questions.
    Thanks in advance,Oth
    Jun 2017
    Stockton,California
    Engine pic.
    Sep 2016
    Anchorage Alaska
    Fox body parts fit, but I'd check with Maximum Motorsports to make sure you get the right one for your car and trans combo. Gong to be a monster with that BB for power!
    Feb 2009
    St Augustine FL
    I used a double hump Mustang crossmember. The ends were too wide to fit the stock 1981 Zephyr frame brackets, so I removed the rearward parts of the brackets and bolted fabricated (read: aluminum angle) brackets to the frame and floorpan. Here are some photos: Name:  Xmember rt side.jpg
Size:  75.1 KBName:  Xmember lft side.jpg
    These also left room to get the exhaust past the crossmember without compromising ground clearance.
    Jun 2017
    Stockton,California
    Thanks guys, little history of the engine I acquired the engine from my brother he abandoned the project after he flat the cam and decided not to put more $$$ into it. Now the engine is in pieces now i have to replace new rods and crank bearings and cams.
    will post more pics.
    Jun 2017
    Stockton,California
    Pics. of bearings and cams
    Jun 2017
    Stockton,California
    Mock up the engine last night and run into a potential problem between the v-cover and b-booster, can I eliminate the booster taller v-cover and replace it with wilwood m/c.
    Hydroboost
    Feb 2009
    St Augustine FL
    X2 on the Hydroboost- as long as you have a power steering pump to power it:
    Name:  Hydroboost Master Cyl front  web 2.jpg
    Jun 2017
    Stockton,California
    I like the hydro boost rout,will look into it after trans cross member and trans mount modifications. Upload pic.of it tomorrow.
    Question: What is the torque for the MAIN Caps with ARP bolts with Girdle?
    Jun 2017
    Stockton,California
    Finishing up on the tranny cross member, mount and complete building a short block heads, intake going on tomorrow
    What are you using for headers, exhaust ?
    Jun 2017
    Stockton,California
    Swap headers are out of my price range, plan on cut and weld on a used Broncos headers
    Sep 2016
    Anchorage Alaska
    Another brake option is electric power brakes. I'm going that route. Don't have good pics but I'll try and find one to post up. The vacuum pump will be mounted out of site behind the front fender but protected by the fender liner. Not cheap, but you always have working power brakes as long as the electrical system isn't totally dead.
