Results 1 to 10 of 10
Thread: 3G upgrade
    Default 3G upgrade
    I am doing a 3G upgrade on my 85 RS. Is the old 3 wire harness still needed?
    Barboursville, WV
    I had trouble finding detailed info on 1g to 3g conversion. There was also some question as to whether or not your gauge would work correctly. So I just took this route, which is simple and keeps a stock(ish) look under the hood.
    Name:  Screenshot_20190610-002704_Samsung Internet.jpg
    If you're refering to the stock alternator harness, no, that goes away with your 1G alternator along with your voltage regulator.
    If you want to keep your amp gauge functional, you'll need to pick up the PA Perf harness: https://lmr.com/item/PA-462802C1/Mus...G-Plug-Upgrade
    You'll also need a fused larger gauge charge cable. Something like this or make your own: https://lmr.com/item/PA-9905/99-04-M...mp-Alternators
    There is also a kit available with an alternator if you don't already have one.
    I don't have any amp gauge so didn't personally use any of the above stuff. Bought pigtails, fuse and battery cable did it all myself. Not terribly hard.
    Thomas
    Yes I have everything to install the Alt. Not planing on using the gauge for now. Thanks all for the help.
    One other thing, where do most of you hook your electric choke to?
    Wire your electric choke to the white/black stripe wire on your voltage regulator plug. You can kind of make out my splice in my pic above (actual splice done at stator wire connector), the white wire that goes into the wire loom runs to my choke.
    Thomas
    Getting everything prewired and I was wondering where to attach the wire from the "I" terminal. On my alt it is green and red.
    Connected mine to the existing green/red wire that went to the original (1G) external voltage regulator.
    Thomas
