Hello everyone,
I'm currently building my 1984 ford thunderbird, I took out the engine and transmission of it. I Rebuiled and resealed the aod transmission. But I have the engine out and saw that it had saw block damage. I was thinking to get a ford explorer with the gt40p heads and to used the aod out the 84. I believe I can still use the mechanical shift linkage for the manual valve but what tv cable could I use for the fuel injected explorer manifold with the 84 aod transmission? Also I also going for tubular k member and long exhaust headers. Which brand do you guys recommend for both items. I seen people that recommend to get 90 degree spark plugs and to wrap exhaust wrap. People also recommend change the cam and valve spring. I'm not really going for a race / track car, I just want a smooth cruise car. What other stuff sould i modify for this king of build. If any of you guys done this kind of build before, I will really appreciate your help, thank you guys in advance.
