Results 1 to 4 of 4
    Jul 2009
    Cherryville n.c.
    Default struts and mounts question
    I just changed my front struts they still were original 1984. I changed them but did not change the upper mount bushings. the problem is if I take the weight off the wheel I can move the upper strut back and forth about 1/4 inch. does that mean the bushings in the top need changing? I did not change them because I thought i the strut came with new bushings and it did not.
    Sounds like new upper mount bushings are in order.
    Jan 2004
    Olathe, Kansas
    Should be no slop or movement at all.
    Now stang-less.
    88 Cougar 5.0
    Try some caster/camber plates from Maximum Motorsports instead
