Results 1 to 3 of 3
    Default 85 GT egr spacer?
    Hi, can anyone tell me on 85 gt 5spd ho engine, on the egr spacer the port that has a rubber cap on it that’s circled in red. is that one capped off from the factory ? I can’t remember... thanks
    Hi Airplane,
    Definitley not capped at the factory. There should be a hose going from that port to a T between 2 valves marked Purge CV.
    See
    http://vb.foureyedpride.com/showthre...vacuum+diagram
    Scroll down to xctasy’s 7/18 post that shows the diagram. If the carbon canisters have been removed then the port is useless and gas fumes are venting to atmosphere.
    Last edited by WilliamCapri; 06-03-2019 at 09:13 PM. Reason: Wrong date in my post
    W
    Ok thanks, I’ll look at these diagrams and I do still have all my canisters & lines etc. The previous owner removed the equipment and now I’m putting it all back together again piece by piece.
    Quote Originally Posted by WilliamCapri View Post
    Hi Airplane,
    See
