Results 1 to 8 of 8
Thread: Spring Rate
    Default Spring Rate
    Are the 93GT front spring rate heavier then 79 base.
    Thanks,
    Ed
    According to a book i have:
    1979 base non V8= 370# constant rate
    1993 handling/GT/hd= 425-530 variable rate
    Jan 2004
    Olathe, Kansas
    That seems light, must be the rear spring numbers?
    Now stang-less.
    88 Cougar 5.0
    93 front spring rate is accurate. I don't know on the 79. I believe they had less rate but were constant so more harsh which aligns with what is mentioned above .
    Jan 2004
    Olathe, Kansas
    I had a brain malfunction and was thinking load rating. Sorry LOL
    Now stang-less.
    88 Cougar 5.0
    Found this
    heres a list of common springs and their rates...
    Rate(lb/in) Drop(in.)
    PartNo. front rear front rear
    '87 Mustang 2.3L 370 160
    '87-93 Mustang 5.0 425-530 200-300
    '93 Mustang Cobra 425-530 160
    '93 Mustang Cobra R 750-850 240-260
    '94-95 Mustang Cobra 400 160
    '95 SVT Cobra R M-5310-R58 700 850
    M-5560-R58 200-260
    '96-98 Mustang Cobra 400-505 165-265
    '99-04 Mustang V6 OEM 400 190
    '99-04 Mustang GT OEM 450 210
    2000 SVT Cobra R (Eibach) M-5310-R00 800
    M-5560-R00 750 (IRS)
    2001 SVT Cobra OE M 500 470 (IRS)
    2001 Bullitt 1R3Z-5310-CA (front) 600
    1R3Z-5560-AA (rear) 250 0.75 0.75 1R3C-5560-AA ?
    2003 Mach 1 3R3Z-5310-AA (front) 600 3R33-5310-CA, 3R33-5310-AA ?
    3R3Z-5560-AA (rear) 250 0.50 0.50 3R33-5560-BB
    2003 SVT Cobra (Conv.) OEM 500 470 (IRS)
    2003 SVT Cobra Coupe OEM 600 600 (IRS)
    BBK Progressive BBK2510 ?? ?? 1 0.8
    Dech Speeddrive 1000-1200 210-280 1.5"
    Eibach Prokit 425-530 200-300 1.50 1.50
    Eibach ProKit Convertible 460-570 170-310 1.5 1.5
    Eibach ProKit Coupe 460-570 200-250 1.50 1.50
    Eibach Racekit 700-850 200-260
    Eibach Sportline 425-630 140-295 2.00 2.00
    Ford Motorsports B M-5300-B 425-530 200-300 1.50 0.75
    Ford Motorsports C M-5300-C 650 200-300 1.50 0.75
    Ford Motorsports F M-5300-F 460-570 200-250 1.50 1.50
    Ford Motorsports G (Conv.) M-5300-G 460-570 170-310 1.50 1.50
    Ford Motorsports R M-5300-R 700-850 200-260
    Global West 800 160 1 1
    Global West Comp 1000 160 1 1
    Global West Drag 680 160 1 1
    H&R Cobra Convertible Race 750-850 770 (IRS)
    H&R Cobra Coupe 700-760 685 (IRS)
    H&R Cobra Vert Super Sport 700-760 685 (IRS)
    H&R Race 750-850 260-280 1.25 1.00
    H&R Sport 490-575 250-285 1.60 1.50
    H&R Super Race 950-1050 260-300 1.25 1.25
    H&R Super Sport Coupe 51652-77 700-760 275-300 1.75 1.60
    H&R Super Sports Vert 51658-77 700-760? 275-300? 2 1.6
    Intrax 2 2
    Jamex 450-550 170-220 1.5 1.5
    Jamex Sportsprings 425-450 180-225 1.50 1.50
    Kenny Brown 650 800 (IRS) 2 1.25
    MAC Progressives 450-520 200-230
    MRT MRT-301 650 200-250 1.25 1.25
    Progress 580 250-300 1.75 1.75
    Saleen (Eibach ProKit?) 460-570 200-250
    Roush Sport SM01-37X0-V8 1.50 0.80
    Steeda Competition 555-8240 750-850 250 1.25 1.25
    Steeda Full Comp [front] 121-4540-001 850-1050 N/A 1.50 N/A
    Steeda Sport 223-9004 650 200-250 1.25 1.25
    Suspension Tech Street 725 230
    Suspension Tech Comp 850 280
    That's awesome information!
    Thanks!
    That list is mostly meaningless.
    You can compare two springs against each other which are linear, but for the most part you can't compare a progressive spring to another progressive spring, or for that matter a progressive spring to a linear one.
    1) Every company in that list uses different criteria to define the points at which the high and low rates are defined for their low and high spring rates. For example H&R uses ride height for the low rate and 2" of bump travel as the high rate. Eibach uses full droop travel as the low rate and ride height as the high rate.
    2) In addition, every company uses a different front and rear spring load to define ride height. With progressive springs this makes it impossible to compare springs between manufacturers.
    Jack Hidley
