Results 1 to 7 of 7
    Default 86 Capri 5.0 still having fuel issues
    I am still having fuel issues that I can't figure out. I can drive the car around, getting it normal running temp, and when I shut it off and try to restart it, it will act like it just ran out of fuel. It will not start unless I wait the next day or break the fuel line apart and then it will start. If I run it for less than 5 minutes or so, I can restart it with no issues. Only wont restart after it is good and warm. Anybody have any ideas?
    1986 ACS McLaren Capri
    1971 Mustang
    1968 F100
    Are you sure it’s not electrical like the TFI getting hot? Check your fuel pressure with a gauge.
    I am planning to check the fuel pressure, but I have to get a new fuel line. The one on the car does not have a Schrader valve to check the pressure.
    1971 Mustang
    1968 F100
    Barboursville, WV
    I thought the efi cars all had schrader valves. Is it a custom fuel rail or what?
    Not sure, but there is no valve anyplace on the line (which I thought was very strange). It looks like a stock Ford fuel line.
    1971 Mustang
    1968 F100
    Not sure about 5.0. The 84 2.3 has the Schrader valve up by the wiper motor.
    The time it takes to crack the line may be enough to cool the TFI, but doesn't the TFI issue cause the engine to quit while running when it heats up?
