Results 1 to 4 of 4
    Jul 2016
    Duncannon PA
    Default Non working temp guage
    I had to replace the heater core in my 84 SVO and after I got everything back together my temp gauge doesn't work now. And yes it worked before. All the other gauges work just as good as before.
    Any ideas? Is there maybe ground wire I missed reattaching somewhere?
    Current Mustangs
    1966 6 cylinder coupe
    1984 SVO 9W
    1985 Saleen #132
    The only ground is engine block to firewall by the heater core.
    What brand heater core did you go with?
    Barboursville, WV
    I believe the wire to the temp sensor IS the ground. Just pull wire off the sensor and ground it. If the gauge goes up, the sensor is bad. If not, there is a bad connection in the harness, behind the dash, or there is a problem with the gauge itself.
    Jul 2016
    Duncannon PA
    Ok. I was checking first. I was going to ground it out just haven't had time.
    Current Mustangs
    1984 SVO 9W
    1985 Saleen #132
