I have a intake (upper and lower) from an exploder and both have some heavy oily film inside the ports. What is the best way to clean them? soak them in??
Past 4 eyes-
U.S. NAVY 1980-2009
I used brake clean to clean mine out.
67 Mustang Coupe
96 Tangerine GT
86 Saleen #179
Soak them in some purple power cleaner, spray them with engine degreaser also.
'86 GT - weekend driver
'86 Capri 5.0
'86 Turbo Coupe
'17 Mustang GT
'23 BRONCO
I do a lot of work on carburetors and I soak them in combustion cleaner overnight. Might take a lot tho. Any rubber gaskets or O rings should be removed before doing so as is the cleaner causes rubber to expand. Parts come out as new.
I always use lacquer thinner to clean oil and sludge type residue. I have an old plastic tote that I cut to size and a couple bottle bushes and tooth brushes that I use while wearing kitchen gloves and eye pro with good ventilation. Works very fast.
Try Easy-Off oven cleaner....
conmech - aka Marshall
