Results 1 to 13 of 13
    Apr 2010
    Portland, Oregon
    Default '85 LTD "351 Police" - $1000 (Canby OR)
    1985 Ford ltd
    condition: fair
    cylinders: 8 cylinders
    drive: rwd
    fuel: gas
    paint color: white
    title status: clean
    transmission: automatic
    type: sedan
    351 police car. Strong 351 . Can't start now because it needs a distributor. New high pressure fuel pump and alternator. Good C4 tranny. Nice mustang wheels. $1,000.00 obo or trade? Whatcha got?
    https://portland.craigslist.org/clc/...887438720.html
    WTF?
    Probably has a 9" rearend as well.
    '95 Saturn SW2
    Apr 2010
    Portland, Oregon
    My thought was that he's confusing 351 with 302 H.O.
    Nice to leave the tow chain still attached when taking the pics. Did they originally come with TRXs?
    Bleed Ford Blue! '84 Grabber Orange SVO, '88 Saleen 1 of 4 w/Automatic, '89 Steeda, '71 DeTomaso Pantera GT5 Wide Body EFI 4.6 DOHC and some Old Ford Muscle w/ BB power. 1.21 Jigawatts!!?? PETRO EXPRESS=CITGO=BOYCOTT!
    No way. That was definitely built stock with a 351M engine three years after Ford stopped making that engine. The "M" in the VIN is all the proof in the world I need. Extremely rare care. I bet that thing runs deep into the 10's in the 1/4 mile.
    '95 Saturn SW2
    Apr 2010
    Portland, Oregon
    Added the VIN tag, did he? Looks like 1FABP38M8FG20840x. He's obviously confused.
    1FABP39M8FG208404
    B = active belts, no airbags
    P = passenger car
    39 = LTD 4-door sedan
    M = H.O. 5.0L V8 engine
    8 = VIN check digit
    F = 1985 model year
    G = Chicago Assembly
    208404 = 108,404th 1985 Ford scheduled for production at Chicago Assembly
    Buck Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Apr 2010
    Portland, Oregon
    I sent him a link to a decoded VIN on foxchassis.com and asked him two questions. His response:
    "Ok, there's the answer! Yes 140 speedo, no tach."
    Feb 2009
    Jackson, NJ 08527
    Though the 85 HO was 215 HP with a carb........
    210 HP with 4V carb/T-5 trans (Capri/Mustang only)
    165 HP with CFI/AOD trans (early Capri/Mustang, LTD/Marquis)
    180HP with CFI/AOD trans (late Capri/Mustang)
    Buck Tag Decoder
    Owner Card Decoder
    VIN Decoder
    That's a HUGE difference! Always wondered why they did that. Automatic couldn't handle the power even though serious drag racers ALL use autos?
    Camshaft/lifters, intake manifold, fuel pump, fuel delivery (carb vs fuel injection), transmission ... all different between 4V and CFI models
    Roller camshaft/lifters alone were 20 HP over the flat-tappet cam/lifters.
    And the 15 HP difference between the "early" and "late" Capri/Mustang CFI/AOD rating was only the exhaust system. The early (165 HP) exhaust was a carry-over from 1984...cast iron manifolds, single muffler, single tailpipe (twin tips) and the late (180 HP) exhaust was the 1985 4V/T-5 set-up (tubular manifolds, dual mufflers, dual tailpipes).
    Buck Tag Decoder
    Owner Card Decoder
    VIN Decoder
