Results 1 to 6 of 6
    Default Distributor Gear?
    I have this Flowtech cam to put in. Do I need a different distributor gear?
    Barboursville, WV
    I believe, technically, you're supposed to use a new gear any time you install a new cam. The style of gear depends on the cam manufacturer. Typically, a steel gear for hydraulic roller cam...flat tappet gets an iron gear. You can use a bronze gear with either one, iirc. The downside is that you would need to check it periodically for wear. A composite gear is also supposed to be compatible with any cam, but without the wear issues. They do cost more, though.
    This is what I've learned. Someone may chime in and correct me if I got anything wrong.
    Good to know. The cam was actually manufactured by Comp.
    Dec 2009
    St. louis MO
    Ask Ed, he would be the best to ask. Beside that Broncojunkie is spot on.
    Keith formerly STLPONDS
    '79 V8 coupe in the works!
    Quote Originally Posted by STL79Coupe View Post
    Yep, probably a good bet. Email sent!
    He said I should be fine with my original EFI era gear. Question answered!
