Results 1 to 8 of 8
    Jan 2004
    Olathe, Kansas
    Default low friction oem ball joints
    Been reading some threads on here about suspension. Lots of good reading.
    Seems the low friction OEM fox balljoints are highly recommended. How would I accomplish this recommendation from MaxMotorsports?
    Now stang-less.
    88 Cougar 5.0
    I personally have never had an issue with ball joint retention in the stock control arms. With that said, I always take care when pressing out the old ball joints to ensure I don't damage or enlarge the opening. There is a lip/flange on the opening for the ball joint, you can use a punch and a hammer to lightly tap that lip in towards the center to shrink the inner diameter of the opening to ensure a good interference fit.
    I just pressed a set of the OEM SN95 ball joints from Maximum Motorsports into the control arms of my 82 RS. No issues and everything fits just as it should. I do use and recommend the "Green" Loctite just as an additional safety measure, but otherwise I didn't feel the need to make any changes to the opening for the new ball joints. The old joints pressed out just fine after using some penetrating lube to help break them loose. The new joint had a nice interference fit even after sitting in the freezer for 24 hours before the install (which is how I install all my ball joints, bushings, etc. when possible).
    Hope that helps and good luck!
    Jan 2004
    Olathe, Kansas
    Thank you. I was hoping didn't have to weld metal or something. I cant do that. LOL
    Now stang-less.
    88 Cougar 5.0
    I had a problem with retention. I solved it by buying new control arms. This was after I had done a bunch of work to replace the bushings in the old ones too.
    The balljoint hole has a lip on the bottom though. I guess it's possible you could reduce the size of the hole by pounding on all of that lip with a hammer... Like with a bearing race installer or something.
    Jan 2004
    Olathe, Kansas
    What spindles are you using? Will those ball joints/spindle (87+ V8 ), tighten down without the nut backing off? Thank you.
    Now stang-less.
    88 Cougar 5.0
    Jan 2004
    Olathe, Kansas
    Follow up for prosperity
    Emailed TRW not much help really. JBJ875 and JBJ869 (Fox style).
    Basically said "no grease zerk = low friction design"
    Now stang-less.
    88 Cougar 5.0
    That should be basically true.
    With a metal on metal ball joint (high friction) the job of the grease fitting is to allow new grease to pump the older grease out, which is filled with ground up metal out of the joint.
    With a metal on plastic ball joint, there are no ground up particles in the joint, so there is no reason to replace the grease as the joint is sealed.
    Jack Hidley
    Sorry I missed this before. I am using the 87+ V8 spindles. Although it doesn't matter. Even the 79-86 spindles can use the SN95 joint. There is plenty of thread engagement for the nylon lock nut to do it's job. You can always add Loctite for additional peace of mind.
    That's good to know. The only thing I will say is that just because they are low friction design, doesn't mean they are the same quality as the OEM Ford parts. Jack can speak to this better than I can. But I bought some Motorcraft balljoints a few years ago thinking they were OEM Ford just in the Motorcraft box. They were not and were not anything like the quality of the OEM Ford parts. I am not saying the TRW joints are bad or not worth a try, just stating that although low friction they may not compare to the OEM Ford.
    In regards to the post above about retention of the ball joints. The lip around the ball joint opening is a metal flange that is just the control arm metal bent over @ 90 degrees. When you press ball joints out, that lip can deform or flare out depending on how well and long the previous ball joint was installed. You can use a metal punch or drift to slightly shrink the inner diameter of the ball joint opening to provide a more interference fit. I recommend being careful as you can make the situation work if you deform the circular opening. It doesn't take much to fix the issue. Often in my case there will be just one area that seems to have flared out and working on that section will correct the problem and the ball joints will install and hold just fine. Good Luck!
