Results 1 to 3 of 3
    Default 93 Coupe Weld Prostar front size?
    Hello everyone!
    I'm looking to swap my current 15x4 Prostars for something wider. I'd like to go with 15x7 4.5 BS. My car has a 5-lug conversion. Not sure if it off a later model Mustang, or say a Lincoln. I asked Weld. The guy there "thinks" that the 15x7 with the 4.5 BS will work. I'd hate to order them only to find that they rub. Thanks
    Garrett
    You may want to call support at Tire Rack. They can tell you +-10% with their models
    How did you convert to 5 lugs? Ranger/Mark VII/SVO front rotors with Fox spindles? SN95 spindles and brakes?
    15X7 with @ 20mm offset (@ 4.73" BS) should fit with Fox spindles.
    15X7 with the SN95 spindles and the same specs will most likely fit fine too, although the wheel would sit closer to the wheel lip by @ 1/8" but that shouldn't be much of an issue with a 7" wide wheel. Good Luck!
