Results 1 to 3 of 3
    Default What's the blue wire in the same look as the oil pressure sender for?
    While working underneath the hood on my 85 mustang GT 5 speed I ran into a blue wire which is in a small offshoot loom routed to the oil pressure sender.Name:  15560681496284026056870103983147.jpg
Size:  125.4 KB This blue wire is a little thicker gauge and significantly longer and in my case does not have an end on it. Anyone have any idea where this blue wire should route to on the engine?
    In will check mine tonight whwn i get home. The only blue I have seen in mine goes to the horns.
    Okay just took a look and the blue wire goes to the oil level sensor that's in the oil pan
