Results 1 to 2 of 2
    Default where can i find the body rubber trim for my 84 dps lx?
    i have found the sides but i need the strip across the rear bumper how sells these? thanks
    I believe this was answered in another thread you started, but just in case . . . The body side molding on the front and rear bumper cover is part of the bumper cover assembly. The entire cover is molded as one piece and the rub strip/body side molding section is not removable or replaceable.
    You will have to either replace the rear cover with a better quality unit or repair what you have. Standard urethane/plastic repair methods work just fine in most cases. High build primer and lots of sanding in addition to different urethane/plastic repair products/fillers will get the job done. Not a fun job, but what it takes quite often. I am doing the same to my 82 Capri RS both front and rear.
    If you look for a replacement cover the 79-84 Mustangs and the 79-82 Capri have the one you need. Good Luck!
