Results 1 to 25 of 28
Thread: Thermostat help
    Feb 2018
    Saskatchewan, Canada
    Default Thermostat help
    Ordering a new thermostat housing(Ford performance) and thermostat(stant superstat195°) for my 91 302. Have the thermostat housing gasket already as part of my fel-pro engine kit but can seem to find the little gasket seal that goes on the actual thermostat. Tried looking on summit as that's where I'm ordering the rest of the stuff. Is there something I'm missing? Can someone link me to the proper seal I need?
    Mustangs
    84.5 Gt T-top
    85 Gt
    Most of the thermostats have a ring on them that gets clamped between the housing and the cut-in groove where the thermostat rides.
    I prefer Gates gaskets because they are self-stick and let you put the thermostat into the housing, apply the gasket, and the gasket has provisions to hold the housing bolts too.
    That particular gasket goes over the thermostat on the housing neck and does the same thing you are talking about with sealing the thermostat into the housing.
    Quite a few of the gaskets do, but are a PITA if they aren't held on with a dab of gun grease, etc.
    A few of the other setups simply don't bother to try to do anything around the thermostat itself. those are even harder yet to install unless the intake is stood up on its end before its installed.
    Don't forget -- the air hole/management setup on the thermostat goes towards the top. Install as springs first into the intake.
    Personally I always use the OE Ford 192 degree thermostats. They cause the temp gauge to show temps right where the car has always ran.
    We recently fought temperatures like mad on my son's 86 and ultimately found not only was the Duralast thermostat from Autozone not opening far enough the pressure cap also wasn't holding enough pressure.
    Needless to say the temp control was marginal at best. We swapped out the radiator for a fresh new one along with the fan clutch and still had trouble and that's when we knew it had to be coolant flow or pressure. It was both. GRRR....
    If you plan to turn your timing up at all and have AC and live anywhere that gets above 90, I strongly encourage a 3 core radiator or a newer design all alunimum like the FB-169, etc.
    Find one where way more cooling capacity than needed is just right.
    Feb 2018
    Thanks for the replies erratic but I'm not sure that helps me lol. I know there is a little o ring that goes between the thermostat and the housing. The problem is the stant does not come with one and I cant seem to find one that fits it.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Feb 2018
    Thanks for the tips
    Mustangs
    84.5 Gt T-top
    85 Gt
    Dec 2009
    St. louis MO
    I know what you're talking about. Go to the parts store and look at another T stat it should come in the box. I'm not sure if you can get the o ring by itself, but you should be able to in my opinion.
    Keith formerly STLPONDS
    '79 V8 coupe in the works!
    The last time I replaced a thermostat on a 5.0 was awhile ago, but I don't remember a gasket on the thermostat. I think the only gasket used seals the housing. I looked on RockAuto at thermostats, and the pictures don't show any type of gasket for the thermostat, just the one for the housing. I don't think OEMs started using a gasket on the thermostat until the late 90s. Anyway, good luck and let us know how you fixed it.
    I changed thermostats in both of my 302’s this year and neither had a gasket on the thermostat.
    My ‘92 2.3 did have a o ring on the thermostat but that’s a totally different setup than a v8.
    The only thing there is on these cars is the ring on the outside edge of the tstat as it sits in the indentation in the housing and the gasket material that goes over the housing and hold the tstat in while you are installing it.
    If you look at the period SBF and BBF engines or even go back to the 60's or 70's pretty much none of them have had anything else.
    Feb 2018
    So is it alright to use a little dab of gasket maker to hold the thermostat in place when installing the housing?
    Mustangs
    84.5 Gt T-top
    85 Gt
    Sure is,
    I used weather strip adhesive on the last one I did because I had it and it dries fast
    Feb 2018
    Quote Originally Posted by AldeanFan View Post
    Sure is,
    Perfect thanks!
    Mustangs
    84.5 Gt T-top
    85 Gt
    Contact cement is what I use. Easy to clean, cheap, and will com off when needed.
    Kenny
    Feb 2018
    Do you guys go all the way around the thermostat? I thinking that would also help prevent leaks if I did that with gasket maker.
    Mustangs
    84.5 Gt T-top
    85 Gt
    I just use a few dabs to hold it in place.
    The only place you need to worry about leaks is the seal between the thermostat housing and the intake.
    Feb 2018
    Ok, thanks
    Mustangs
    84.5 Gt T-top
    85 Gt
    The gates gasket is self stick. It has provisions to hold the thermostat in the housing and also hold the bolts while you are putting the housing on the intake. Best I’ve found
    I have (seasonally, 180/195... clean both intake and housing sealing surfaces thoroughly, and block sand the housing surface if it has "cupped" some away from being flat...) changed thermostats on a couple SBF (yes, their vertical orientation can be a beeotch, lol) equipped vehicles for "a hundred years", and with the thermostat set into a thin "bed" of Ultra Blue in the groove of the thermostat housing, then finger swiped around with thermostat in it, the gasket set on and positioned with the bolts in temporarily backwards, then set the neck of the housing onto the radiator core so that it'll stand up that way for a while and cure the goo a bit... and then onto the intake manifold it all goes... and I've never ever had any issue.
    Apparently many on here are not aware of a feature on a t-stat housing that I used as a tech. numerous times to hold the t-stat in place without using any type of adhesive.
    When installing the stat make sure the bleed hole is up and it is flush with the housing, then give the stat a slight twist in the housing and it well hold or lock in place, I usually twist it clockwise and it doesn't move a great amount before it locks, then install the gasket with a slight amount of adhesive.
    Feb 2018
    Quote Originally Posted by gt pony View Post
    Hmmm, well I tried what you said and mine does not lock into place no matter how many times around clockwise I turn it. Stock 91 housing and a stant superstant 195° thermostat.
    Mustangs
    84.5 Gt T-top
    85 Gt
    I should have clarified my post better, a OEM Ford t-stat not an aftermarket one. If you look at a Ford t-stat housing and t-stat you should notice there is a raised portion on the stat where it sits in the housing and a corresponding indent on the housing so the stat is installed in the up position for the bleed hole. When installed properly you just need to give it a twist. If I had a picture you would see what I mean better, but I think you'll see what I mean when looking at the housing providing it's an OEM and Ford t-stat.
    I need to clarify further that Stant t-stats are a good product but they are not manufactured the same as a Ford OEM t-stat when it comes to this feature.
    Feb 2018
    So are the OEM Ford t-stats the motorcraft ones?
    Mustangs
    84.5 Gt T-top
    85 Gt
    Yes they are.
    On EFI cars I always stick with 192 degree Motorcraft thermostats. They consistently put these ol motors right on the money temp wise.
    Feb 2018
    Would it be same for Carbed?
    Mustangs
    84.5 Gt T-top
    85 Gt
