Results 1 to 2 of 2
    Sep 2014
    Freeport NY
    Default Tensioner repair
    Are belt tensioners rebuildable?
    I know, buy a new one right/ The old style has a bracket that you can easily depress with a pry-bar or crowbar. I don't like the new after market types. When I rebuilt my motor 2 summers ago the only thing I kept from the old build was the tensioner
    I found one guy that has a NOS old style tensioner on ebay for $110 but that's a bit too pricey. I'm sure the pulley bearing is whats shot and I know that can be pulled and replaced. but can the tensioners internals be replaced too?
    https://www.ebay.com/itm/E2ZZ-6B209-....c100290.m3507
    I've seen guys take them apart and flip the spring so they pull up instead of push down.
    I always just slipped something between the pulley. Just about anything will work, a long extension, tire iron...
