Originally Posted by
83gt351w
Messing with the timing on my 351W. I’m running the vacuum advance to the metering block. Once the car is warmed up, it really seems to like the initial timing with vac advance unhooked set at 10 degrees btdc. When I start going higher, the idle isn’t as smooth, and at 16 degrees the best way to describe it, is the engine bucks back on the starter. Any lower than 10, it idles terrible.
Its an aluminum headed engine with a 296/302 duration cam. Checking the net, it seems initial timing recommendations are all over the place. Is this as simple as “well, this is what my engine likes.”?
IIRC, my total advance was 30. Which I believe can be adjusted as I have a dizzy that looks like the vac advance cap can take a wrench.
