Results 1 to 25 of 32
    Default I Need New Shock Absorbers...
    I need new heavy duty coil-over rear shock absorbers for my 1980 Fairmont Sedan. For many years I've purchased and installed 'Monroe Sensa-Trac Load Adjusting Coil-Over Shock Absorbers' part number 58428. (see attached)
    http://www.monroe.com/en-US/e-catalog/58428/
    However these shock absorbers are apparently now obsolete and I haven't been able to find them anywhere. I tried 'Bilstein' also but no luck there either. Does anybody have a good part number and brand name for a heavy duty coil-over rear shock absorber for a Fox Chassis Ford (something that will fit my application)?
    I'm a little surprised and very disappointed that the Monroe shocks that I've been using all these years are no longer available...
    Current Fox Fleet
    '82 Zephyr GS Two Door 3.3
    '80 Zephyr Sedan 3.3
    '80 Fairmont Sedan 3.3 (X2)
    '81 Fairmont Sedan 5.0
    '86 Mustang LX 4.2
    We have several different shocks and coilover kits that will work in that application.
    Do you have any idea what the spring rate on the Monroe shocks was?
    Jack Hidley
    Thanks for the reply. It is most appreciated.
    But no, I don't know what the spring rate on the Monroe shocks are. The Monroe website doesn't tell us and I wouldn't know how to determine that otherwise. Can you post a link to show me the type of kits that you're talking about? Would it be possible to use one of your 'kits' to remount the old spring onto a new shock absorber?
    Reusing the old spring on a new shock absorber was something that I had already considered doing but I hadn't yet figured out the best way to do that. I use the coil-over shocks because I often tow a small utility trailer with this car. The car is a sedan but it has station wagon rear springs. The max tongue weight on my trailer hitch is 200LBS...
    Current Fox Fleet
    '86 Mustang LX 4.2
    Mar 2013
    Where the Navy sends me...
    I searched for the part number (Monroe 58428.) on rockauto.com. The Parts Search did find that part number, but showed it as out of stock (as you said). When you click on the part number, it'll show you what make/model/year applications use that part number. You can also click the "Info" button to find out specs, including extended and compressed length. That info page shows "Spring Rate: 28" for the Monroe 58428. No dimensions there, but presumably that's 28lb/in?
    Looking through the Suspension - Shock Absorber listings for a couple of the other make/model/years listed, I see that there are some air lift setups - Monroe MA810 and Gabriel 49199 or 49196. The Gabriel 49196 looks too long - it's extended length is 3" longer - but the MA810 and 49196 both match up pretty well dimensionally to the Monroe 58428.
    Interestingly enough, Rock Auto shows that the full-size LTD used essentially the same rear shock absorber setup - the Applications list for the Monroe 58428 shows the '83-86 LTD Crown Victoria. So I went to the '85 LTD and found Monroe 550051 for the "Rear; Crown Victoria; w/ Police Package; For Towing and Hauling". It doesn't list the spring rate, but the dimensions look about right.
    Digging even further, if I click on the 550051 part number, it shows it fits the '83-86 LTD Crown Vic and the '93-02 Crown Vic. OK, so let's look at a later gen car. I pulled up the shocks for a '98 Crown Vic and in addition to the Monroe 550051 ("Rear; Police Interceptor; For Towing & Hauling") there's also a Monroe 58568 ("Rear; Base Model; LX Model; S Model; w/o Touring Suspension"). 19-7/8" extended length vs the 20-3/8" of the Monroe 58428, variable rate spring (looks like maybe it's a higher rate spring?).
    If you really want to dive into the rabbit hole, click on the part number for one of the "normal" (non-coilover) rear shocks, like the Motorcraft ASHV9 or Bilstein 24184755. That application list comes up with a bunch of classic, RWD solid axle cars - you could start digging through those to see if you find other coil-over options in addition to what I've come across so far.
    @ Patrick Olsen
    Many thanks for that load of info! You've been most helpful!
    I am now considering (based on the information that you've provided) going with the Monroe 550051. It seems to be a pretty close match to the obsolete Monroe 58428. I also like the idea that the Monroe 550051 was for a heavier car. I do quite a bit of hauling with my Ford Fairmont.
    The Monroe 550051 is 1/3 of an inch shorter than the Monroe 58428 which I'm using now. I guessing that that shouldn't really make much difference...should it???
    (Also, it appears that the Monroe 550051 dimensions are very close to the shocks that the Monroe website shows fitting a 1980 Ford Fairmont
    http://www.monroe.com/en-US/e-catalog)
    Current Fox Fleet
    '86 Mustang LX 4.2
    Could call or email them see what they say:
    http://www.monroe.com/en-US/resource.../contact-info/
    1-734-384-7809
    8:30 a.m. - 5:30 p.m. EST M-F
    1-734-384-7809
    Actually I had already emailed Monroe. They told me that the shocks that I had initially wanted ( Monroe 58428 ) were obsolete and that they couldn't help me. I now have my local parts jobber trying to hunt down a pair of Monroe 550051 shocks. With all the information that Patrick Olsen provided me, it looks like the Monroe 550051 should work. The 550051 shock is almost the same size as the obsolete 58428 shock but it is just meant for a bigger and heavier car. Even the mounting hardware is the same.
    Being that the two shocks are for two different applications, I really doubt that Monroe would say that they are interchangeable even if they in fact are...
    Current Fox Fleet
    '86 Mustang LX 4.2
    Autolite,
    I think it would help a lot if you told people what problem you are trying to fix here with the coilover shocks.
    If you trying to make it so you can drive the car with a trailer behind it and not have the rear ride height get so low, then installing some RLCAs with adjustable height lower spring perches is an easy fix. When you attach the trailer, just use a ratchet to raise the back of the car up.
    https://www.maximummotorsports.com/S...998-P1492.aspx
    Jack Hidley
    Autolite,
    Maintaining a decent ride height while hauling a load is indeed the goal. And I found that I was able to do that with those Monroe coil-over shocks that I had been using all these years. But thank you for your help, the link and the additional info. It's really good to know that there are other options...
    (BTW, I found out many years ago that the length of the RLCAs varies between the different Fox Fords. I believe that the Mustang has shorter arms than the Fairmont. What would be the reason for that?)
    Current Fox Fleet
    '86 Mustang LX 4.2
    Thunderbird, Cougar and Lincoln Mark VII RLCAs are 0.39" longer than Mustang RLCAs. The reason is that these cars are designed to have a softer suspension than a Mustang, so they need to have more total travel. When you increase the total travel of the suspension, you need to make the RLCA longer so that the tire doesn't move too much fore/aft as the suspension moves up/down.
    All other Fox chassis cars use Mustang length RLCAs.
    Jack Hidley
    Mar 2013
    Glad I could help, Autolite. Sometimes it's intriguing to dig around the parts search engine and see what one can find.
    I was thinking maybe one of the air spring options would be better - that way you could air 'em up when you've got the trailer on there, and bleed 'em down when you don't need the extra help. I've never had such air springs, but the Gabriel listings say "• Easy to inflate at any service station, at home with an air compressor or with continued use of an existing onboard air management system", which makes it sound like it would be pretty easy to do.
    Anyway, keep us updated when you get the new parts installed.
    Two alternatives:
    Monroe air shocks
    Air Lift brand air bag coil spring inserts
    Thanks for that info. I thought that it might have something to do with the ride and/or the weight of the vehicle but I just wasn't sure how the length made a difference...
    Current Fox Fleet
    '86 Mustang LX 4.2
    I'm still waiting to hear back from my local parts jobber on the Monroe 550051 shocks that I'm wanting to get. I'm in Canada and finding this stuff can sometimes be a real bother. In the meantime, I have installed a serviceable pair of used Monroe 58428 shocks that I had removed from one of my wrecks. That'll have to do until they can find me the new Monroe 550051 shocks.
    Again, many sincere thanks to you and the others for all the help. It is much appreciated...
    Current Fox Fleet
    '86 Mustang LX 4.2
    Jul 2007
    Richmond, ME
    I have a 1986 LTD Crown Victoria that I'm shopping for rear shocks for.
    The Motorcraft shocks for the Panther chassis are the same as the Fox chassis part number.
    Monroe shows a 58568 which looks EXTREMELY similar to the 58428 you posted at the top.
    Jack: Bilstein question. I have a pair of used 2003 Cobra IRS Bilsteins that I'm not using (because I have the MM coilover Bilstein set for the Zephyr IRS).
    The IRS Bilsteins have the extension above the lower mounting eye, to clear the control arm; but otherwise the mounting and lengths are pretty close to the solid axle shocks.
    Can the IRS Bilstein be used in the Fox (or in my case, Panther) rear? The Panther of course is much heavier, and I do use mine for towing and more than an occasional trunk full of automotive or construction supplies. I have a new set of Bilsteins on the front as well.
    They're free, so I might just try it and see. I want the sag and sog out of the suspension; it's no performance car and I just want to be able to take corners without getting seasick.
    The Mustang IRS shocks won't work in a solid axle application.
    The lower eyelet is setup for a 14mm bolt, not a 12mm bolt.
    The IRS shocks only have 5.4" of travel. SN95 Mustang solid axle shocks have 7.3" of travel.
    Because the IRS shocks are mounted inboard on the LCA, the low motion ratio requires that they have twice the overall damping of a solid axle shock. In addition because the IRS has 100lbs less unsprung mass than the solid axle, the amount of compression damping is much less and wouldn't work with a solid axle application.
    Jack Hidley
    UPDATE:
    The Monroe 550051 shock absorbers are now on order. My local parts jobbers tell me that this number is also obsolete. None available in Canada they said. Order was placed through Amazon.com. Estimated delivery is two to three months...
    Current Fox Fleet
    '86 Mustang LX 4.2
    Grand Rapids, MI
    Shows only one remaining on RockAuto. That could very well be the last new one in the world.
    https://www.rockauto.com/en/parts/mo...+absorber,7556
    Have you considered coil spring helper air bags? At least you can pressurize and depressurize them as you need them rather than living with a harsh ride all the time.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
    Yeah, I've seen that link. I can't imagine how they're going to sell just one shock.
    I really don't mind the hard ride. I've been installing the Monroe coil-over shocks for many years. I've always put them on all my Fairmonts, Zephyrs and LTDs. I guess it's now my own fault that there are none left...
    Current Fox Fleet
    '86 Mustang LX 4.2
    The new shock absorbers are not the only things that I find hard to get now. Finding new exhaust pipes has become a real PITA too! I've found that the front brake pads are also getting harder to find. I'm now starting to wonder how much longer we'll be able to keep these Fox Fords on the road...
    Current Fox Fleet
    '86 Mustang LX 4.2
    Front brake pads from a Cortina 4.1 six or HQ Holden fit, and the rear shocks are also std on other US market cars, staring with the 1964 AMC Ramblers. Huge commonality of parts exist..
    Grand Rapids, MI
    Quote Originally Posted by Autolite View Post
    Convert to later model Mustang front brakes. Problem solved.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '97 Thunderbird
    '85 Ford LTD Squire
    Converting to a newer brake is indeed a viable option. I have several spare sets of LTD/Marquis front brakes that I can swap over onto a Fairmont and hopefully that should do for a couple of more years.
    As a matter of fact, that's now the plan when Fairmont front brake pads eventually become non-existent. Another option would just be to have the old brake pads relined. There is a specialty clutch and brake shop in my vicinity that does exactly that kind of work...
    Current Fox Fleet
    '86 Mustang LX 4.2
    See http://vb.foureyedpride.com/showthre...Shock-Diameter
    Any other shockes that meet the general type will have the 8" of travel JH speaks of.
    I've noted that Monroe # 5847 OE Spectrum Passenger Car and #33097 Monro-Matic Plus is the common replacement for:-
    FORD FAIRMONT (1978 - 1983)
    FORD GRANADA (1981 - 1982)
    FORD LTD (1983 - 1986)
    FORD LTD CROWN VICTORIA (1983 - 1986)
    FORD MUSTANG (1979 - 1993)
    MERCURY CAPRI (1979 - 1986)
    MERCURY COUGAR (1981 - 1982)
    MERCURY MARQUIS (1983 - 1986)
    MERCURY ZEPHYR (1978 - 1983)
    The PO got # 15-3137 series Monroe Tenneco Australian GT Gas Pressure 230603 A replacements before, they are a standard
    1964 to 1972 AMC Rambler/Javelin
    1978-1993 HOLDEN Commodore VB, VC, VH, VK, VL, VN, VP,
    1993-07/1997 HOLDEN Commodore/Calias VR, VS V6 & V8
    1964 to 74 TOYOTA Corona RT40, RT80, RT81, RT82
    1972 to 1977 TOYOTA Corona MK II 6 cyl Sedan
    1975 to 1981 TOYOTA Corolla KE30, KE35, KE40, KE45, KE50, KE55, KE60, KE65
    12/1976 to 08/1980 TOYOTA Cressida MX36 2.6liter
    09/1982 to 07/1984 TOYOTA Cressida MX62 2.8 liter
    1971-1983 TOYOTA Toyo-ace Van
    UPDATE:
    UPDATE
    I just got a notice from Amazon today that the 550051 shock absorbers that I had on order with them are not available either. I've struck out gain. I guess that I'll just have to keep the used shocks that I've temporarily installed on and see how long they will last...
    Current Fox Fleet
    '86 Mustang LX 4.2
