Results 1 to 7 of 7
    Default Another gear pattern question...
    Do you guys think this is acceptable or do you think the pinion needs to come in more? Any advise is greatly appreciated. Name:  20190410_094007.jpg
    1984 convertible 5.0 auto.
    Coast sideName:  20190410_094606.jpg
    Referencing my gear pattern chart, it appears you need less pinion shim. Pinion running too deep in teeth of ring gear.
    Thomas
    Damn close, but what my friend Thomas ^^^ said, yep yep
    May 2016
    Lake City Pa 16423
    Hows the backlash?
    My opinion as well but I’m no expert and have never done it.
    Quote Originally Posted by rich75043 View Post
    looks about right to me...I've set a few of the gears up with that wear pattern...if you have it to close to the end of the teeth , there's not much meat there and you will start breaking or cracking the ends of the teeth.
    Stephen Johnson
    SS/D 427 Ford Fairlane NHRA-IHRA
    National Record Holder 9.49 @ 139mph
    1985 Mustang daily driver
    10.88mph 125mph N/A 337
