Thread: Weather strip
    Default Weather strip
    New to this forum.
    I have an 84 convertible. Can someone instruct me on how to replace the outer door belt weather strip.
    It just lifts off. Gently pry it up from the rear. There may be 1 screw buried in the rubber at the rear (on ASC cars only). For better access, remove the side mirror. The lower flat trim stays in place as it is bolt from inside.
    Mirror. Remove the rubber knob cover. Loosen the set screw if needed. Remove the screw holding the inside cover on. Remove the 2 or 3 nuts holding the mirror on.
    Btw, the New w.s. Comes with the trim and the trim is often damaged in shipping. The trim can be separated and reuse your old trim.
    Thanks so Much
    this my sound stupid how does this mirror come off?
    what is the best site to get the part LMR ?
    Read the second paragraph on removing the mirror.
    Likely only 1 manifacturer. I would go with the one who will resolve shipping damage!! Expect it to be damaged.
