Results 1 to 16 of 16
    FEP Power Member David Claflin's Avatar
    Oct 2008
    Redneck Riviera, Fort Walton Beach Florida
    Default Possible issues with brake component combination....
    On this 1986 SSP, I converted to 4-wheel disc brakes, and instead of installing an SN prop valve, booster, and master cylinder like I normally do, on this one I've got an SN booster, gutted prop valve, installed adjustable prop valve, reman'd stock replacement master cylinder, all new soft lines, calipers, pads and so on. I've bled and bled this thing, get a nice steady stream of fluid out each time, but cannot get a firm pedal. Thinking I may need to put an SN master cylinder on it using this kit. https://lmr.com/item/MM-MMBAK17/Must...aster-Cylinder
    Any ideas?
    1985 LTD LX, Mach1 brakes, 17" Mopar police car wheels. 302, T5, 4.10s
    1986 FHP coupe, stock shortblock, TW heads, Holley SMII intake, 4.88, T5Z
    1990 Red LX, ported AFR heads, TFS-R box upper, weenie cam, 1 3/4 long accufabs, 3" exhaust, T5, 4.56
    You need a larger diameter master cyl
    1” bore is my personal preference
    1973 Torino is a direct fit
    M1858 requires one line adapter
    -- James
    My four eyed foxes:
    past foxes -
    Oct 2008
    I though stock was a 1" bore, but just double checked and it's a 21MM, which is a 53/64. RockAuto shows them as 1"
    Mar 2013
    Where the Navy sends me...
    Quote Originally Posted by David Claflin View Post
    Which configuration were you looking at on RA? I'm assuming your SSP is a 5.0L car, right? I'm only finding 21mm for that combo. I'm curious which 1" one you stumbled across; always nice to have options (in case the '73 Torino option falls off the plate).
    I'm going through this now. Stock replacement brake booster since my understanding is you have to clearance the shock tower on '86 and older for the cobra/sn-95 style booster. '94/'95 gt master cylinder. I dunno if the mounting location for my proportioning valve is messed up but the lines in the kit you linked were way too long for my application. Hoping to have everything buttoned up by the end of week, can provide some feedback at that time.
    Oct 2008
    They're all showing .82 or 21MM, even on Oreilly's site too, so I must have fat fingered something along the way. The brakes work, the pedal is just softer than I like.
    My 90LX has a 1" bore, using a 99 V6 MC, and the LTD LX has the MC from a 1994 Cobra, that one is 15/16, but it's also got the Mach1 brakes, I'm very pleased with how both of those work. I apparently just boogered something up while looking for info on the stock master cylinders of these cars. I've got a 99V6 MC on the way from rock auto so will get that on next week sometime when it shows up.
    the 2000 v6 master cylinder is a 1" bore. that's the one I used with a fox brake booster on my 66 mustang
    Jeremy
    Barboursville, WV
    Quote Originally Posted by snavesa View Post
    I saw the other day where a guy drilled a hole right beside the booster mounting hole (inside hole... closest to the middle of the car). Simply open up between the old and new hole...essentially making a slot. This will give you the clearance you need without beating on your shock tower.
    You still have to beat the tower on the early cars unfortunately. The later years had more room
    Jeremy
    Yep, I definitely had to slot the hole AND clearance the strut tower.
    Do stock master cyl to brake pedal push rods get reused when changing over to something else?
    Like the 2000 V6 m/c or Cobra stuff?
    Plastic tank style shows fluid level and color, bale style no. Interchangable?
    Soft pedal?
    https://techtalk.mpbrakes.com/how-to...r-cylinder-gap
    Thanks guys for the posts. Gitting an idea what to change out and what not to.
    Learned facts i did not know:
    Larger m/c bore = less pedal travel & more effort
    Smaller m/c bore = more pedal travel & less effort
    A small difference in size can make a big difference at the pedal.
    Booster size pretty much changes with m/c bore size.
    Rock Auto, as usual, provided basic specs like sitting on a stool with the books did. Cardone brand lists bore sizes.
    Found out differences between my 79 Mustang and 93 Ranger, which has a much better overall braking feel to me.
    Same 60mm caliper pistons, 9" drums, same engines.
    Truck weighs more, larger rotors (10.2 vs 9.2), larger m/c bore (1" vs 7/8") and booster (225.3mm vs 222mm).
    Truck has very similar sized parts like the 93 Cobra m/c and huge booster. No bottom m/c port either.
    Also found a video that cleared me up on the basics of Ford mc types.
    What i have, whats out there, and what you guys already know.
    https://www.youtube.com/watch?v=JyBaqmhIAkE
    The push rod is part of the booster,
    New booster comes with the push rod.
    Oct 2008
    Quote Originally Posted by v8only View Post
    Yeah, this one took some wailing on the back side of the tower to get it right it in to seat good. Have to do the same thing on the dugan wagon later this summer, but at least that thing is stripped. Need to do that before painting the engine bay.
    Took longer to get a good test in. Stock booster, 94-95 master cylinder (1" bore). Pedal feel is decent, not as good as I hoped at first but got better as I drove. Its definitely a step in the right direction.
    Mar 2013
    Maybe I'm getting myself confused on the different options, but I thought the '94/95 V6/GT master cylinder was 1-1/16"?
    That was my understanding.
    1994-95 Cobra 15/16"
    1993 Cobra 1"
    1994-95 GT/V6 1 1/16"
    1984-86 SVO 1 1/8"
