Results 1 to 4 of 4
Thread: Door switch
    Nov 2014
    Grand Rapids, Mi
    Default Door switch
    I know they make new door switches, but what about the plug? Mine was so corroded it broke when I took it apart. I’d like to get it taken care of before I install the kick panel. Name:  878E5E5C-7A5E-4A48-A6DD-705CFDFC25D7.jpg
Size:  161.8 KBName:  878E5E5C-7A5E-4A48-A6DD-705CFDFC25D7.jpg
    Jul 2016
    Duncannon PA
    I only see 2 plugs so I'm assuming it's for the passenger side?? The only thing I see broke is the switch. The plug is fine. Get a tiny file or something like that to get in the female terminals to clean them up. I think pigtails are available though if you want to go that route. Iirc there is just one plug that fits either side.
    Current Mustangs
    1966 6 cylinder coupe
    1984 SVO 9W
    1985 Saleen #132
    Nov 2014
    Grand Rapids, Mi
    It is for the pass side. I believe the plug has male prongs that go into the switch. Only one remaining. The rest broke off in the switch.
    I would just hit the yard and snag one. Cut and Rewire it and be done. But if a yard is not readily available.........
