Hey guys I just bought a new upr kmember to use with my 351w swap. I'm running a canton 15-670 pan and a power rack. The rack is maybe 1/16" off the oil pan after putting offset rack bushings on and grinding the top of the steering rack slightly. I've read your suppose to have around 1/4" clearance. I have energy suspension motor mounts and also had to use washers stacked up to1/2" between the block and mount to get the 1/16" clearance. The 1/2 stack of washers is causing my collectors to be very close to the bottom of the floorboard. Only thing I can think of doing now is to buy kmember spacers and space It down then space the motor mounts up higher with more washers. Any other ideas??
